gt32 turbo help
im after doing a 2.1 zvh convertion for my escort and was thinking of getting a roller bearing turbo.
can anybody tell me if i get a gt32 will i have to have a custom manifold made ?? if so who does em ???
also which housing would you recomed to use ?? is 0.69 to big ??
sorry i dont know much about turbos hence why im asking
thanks in advance
thanks in advance
GT32!!??!!
Thats a bit big!!
Yes, you will more than likely need a Custom Manifold. With my GT Series Turbo we had to alter everything (Exhaust Manifold, Inlet and also build a Custom Downpipe).
Hope this helps.
Thats a bit big!!
Hope this helps.
Originally Posted by Christian and Beccy
GT32!!??!!
Thats a bit big!!
Hope this helps.
Thats a bit big!!
Hope this helps.
would you be able to do the custom manifold for it ???? and what housing would you recomend ???
imo .69 if thats the smallest they do. Why not go down a step to something like a GT30 or even a GT2871R whuch is good for 400bhp@fly if you run it full whack
I can't help thinking you might be better off all round with a T34 with .63, bolts onto standard manifold with no mods as well. Think you might need a custom down pipe and thats it.
Its all about the drivabillity, will be well laggy with the GT32..I was going the same sort of route but eventually after convo's on here realised it would be a nasty car to drive every day and that wasn't for me.
Mark
Mark
alrite rob,
you at the fiesta's v escorts this year?
Sorry to hijack thread, but I was thinking of using a t34, but ppl told me that may be too laggy and instead i may be better off using a 'stage 3' t3?? any help? any help?
p.s is going on a 2.1 16v
cheers
nath
cheers
nath
well im all up for sugestions if a gt32 is going to be to laggy ill leave it alone
i have been looking on this site http://www.turbocalculator.com/sale-garrett-gt.php and cant seem to find the 1s you have listed. is a T3/T04E 57 Trim Hybrid Turbo the same as a t34 ???
thanks for the advice
Originally Posted by mrviper
http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=GRT-TBO-022&Category_Code=GRT
as for the fiesta vs escort ill try and make it this year when is it ???
Originally Posted by Nath-25/09
alrite rob,
cheers
nath
cheers
nath
what about 1 of these ?
Garrett T3/T04E Hybrid Turbos
Perfect for high HP turbocharged four and six cylinder engines. 0.50 A/R compressor housing. Choose exhaust housings from 0.48 A/R and 0.63 A/R turbine housings. Choose from 40, 46, 50, 54, 57, 60 Trim Garrett compressor wheel
which is best to get 0.48AR or 0.63AR???
what is the trim? and which one would be best for a 2.1 ???
sorry for all the questions just want to get the best 1 for the job
[/img]
[/img]
The above one just is very similar to a T34.
IMO for a 2litre+ ZVH id go for either a .48/.55/.63 ex housinged EscCossie T34, all of the above on a engine that size will be not that laggy (they not on a cossie an your engine is bigger!).
Take your pick on the ex housing size, id prob go for the .63 T34 on a 2.1 myself.
If you want to get fancy then go for somthing from the GT series, but itl involve a lot more arsing around than just bolting a cossie T34 to it
really wanted a roller bearing 1 but i cant seem to find 1 that is just right so i think ill just get the 1 above think it is only 700 dollars so its mucho cheapness
itsmeagain thanks for the help
just 1 more thing whats the best trim to get ??
JK12
33
Apr 26, 2021 12:09 PM
