Oil coolers for road cars,worth it ?
Old 28-12-2010 | 03:11 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Oil coolers for road cars,worth it ?
Or not ?
Old 28-12-2010 | 03:16 PM
Gav Diamond's Avatar
Gav Diamond
Do you know what sort of temps you are hitting at the moment mate?
Old 28-12-2010 | 03:17 PM
KSA-Cossie's Avatar
KSA-Cossie
Not a clue Gav,the saphs just a fast road car will never see a track.
Old 28-12-2010 | 03:18 PM
rstdave's Avatar
rstdave
Depends on how hot you find your oil gets.....fit a gauge and find out, if it's goin over 120 you really need one
It's VERY unlikely you'll need one imo unless you venture out on track in the summer, though you could always fit a thermostatic one so it only flows through the cooler when the oil reaches a certain temperature, and therefore won't overcool the oil.
Old 28-12-2010 | 03:24 PM
Gav Diamond
As above although not sure on the reliability of the stats found in oil cooler kits
Old 28-12-2010 | 03:26 PM
pee vee's Avatar
pee vee
Just for show on a road car.. + if it's 4x4 then it already has a cooler mate
Old 28-12-2010 | 03:43 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
You are very unlikely to get your oil up to the correct temperature in a road car let alone need a cooler.
Old 28-12-2010 | 04:19 PM
Too much guesswork here, even by rod, the question can't be answered realistically unless you know for certain what temps you are reaching, my old xr4i for example maintained a steady 130C at 55mph on a hot day, so had one, having heard how much noisier the cossie gets as the oil thins out, esp with castrol oil, I fitted one for peace of mind, with a stat, as like to keep nearer 80C - 90C.
The temps are likely to shoot through the roof on a cossie oil wise, the oil does at least as much cooling as the coolant don't forget, cruising should be ok but sudden big bootfulls is lots of extra heat to dissipate, gives the cooling system an easier time as well, and with a stat will always be ideal temp.
Old 28-12-2010 | 04:27 PM
pee vee's Avatar
pee vee
something wrong with your temp gauge or engine then mate!
standard unstressed engines running 130c at a steady 55 mph???
so when you were sitting at 80 mph on the motorway for an hour.. 150+ deg c??
Old 28-12-2010 | 04:39 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Why do they have oil modine's then ?
I run a cooler with a thermostst.
The oil even gets warm enough to open this time of year.
Steve
Old 28-12-2010 | 05:34 PM
funkybrian's Avatar
funkybrian
Alright Kev,
Whats been happening with yourself??
How is the car going with the new engine? Did you get a new turbo?
Cheers Brian
Old 28-12-2010 | 05:41 PM
KSA-Cossie's Avatar
KSA-Cossie
Originally Posted by funkybrian
Alright Kev,
Cheers Brian
Hey Bri,hows it going m8 ? Engine is going brilliant,I got R/B T38 in the end still to be live mapped though. Hows the job ?
Old 28-12-2010 | 05:42 PM
KSA-Cossie's Avatar
KSA-Cossie
Steve
You recommend one then Steve ?
Old 28-12-2010 | 05:45 PM
Gav Diamond
Oil needs to get to higher temp than 80C i would imagine to burn off the condensation that is present.
Steve
My understanding was that it is to heat the oil quicker..
Old 28-12-2010 | 05:48 PM
cossiedave's Avatar
cossiedave
dont think that oil cooler is worth £350 tho m8 you can get the same kit on the bay £141
Old 28-12-2010 | 05:51 PM
KSA-Cossie's Avatar
KSA-Cossie
Cheers Dave,i didnt have a clue re price tbh.
Old 28-12-2010 | 05:53 PM
cossiedave's Avatar
cossiedave
that is way to much money m8
Old 28-12-2010 | 06:13 PM
STUCOS's Avatar
STUCOS
Kev dont bother,i never did,never saw oil temps high enough,
cheeRS stu
Old 28-12-2010 | 06:14 PM
Ginge !'s Avatar
Ginge !
just finding my feet
if alot of high speed driving then yes deffo neede BUT fit a oil temp gauge as if the oil aint upto temp then you will cause more damage
oil should be around 100 to 110degrees temp for the correct viscosity,,,,,,, 80 degrees is wrong but as already mentioned its clear tabethas gauge is reading about as acurate as IMA's arse dyno whilst stoned
Old 28-12-2010 | 06:18 PM
KSA-Cossie's Avatar
KSA-Cossie
cheeRS stu
Tried to call you but couldn't get a signal.
Old 28-12-2010 | 06:25 PM
STUCOS's Avatar
STUCOS
Try the house phone,
cheeRS stu
Old 28-12-2010 | 06:26 PM
STUCOS's Avatar
STUCOS
Kev saw the kit your looking at,the guy must be smoking crack at that price
cheeRS stu
Old 28-12-2010 | 06:50 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
When i collected my car from Spec-R it was around 1 or 2c. Took the car for a drive before going home to check things over and the theromstat opened on my oil cooler. I couldn't even drive the car hard due to wheel spin lol.
I don't have a oil temp gauge in the car so no idea on oil temps.
Steve
Old 28-12-2010 | 07:00 PM
funkybrian's Avatar
funkybrian
Job is spot on mate, making some money for a new RS focus!!!!!
Do you feel a difference with the R/B??
Old 28-12-2010 | 07:01 PM
funkybrian's Avatar
funkybrian
cheeRS stu
Thats cause you never drove it hard enough! lol
Old 28-12-2010 | 07:05 PM
STUCOS's Avatar
STUCOS
kev wouldnt know a centre bearing from a wheel bearing
at least my taxi saw day light lol
Old 28-12-2010 | 07:24 PM
KSA-Cossie's Avatar
KSA-Cossie
Yup,and love the T38.
Fpmsl.
Nasty,but true lol.
Old 28-12-2010 | 07:48 PM
Jon(M600BHP)'s Avatar
Jon(M600BHP)
Quality replies above
You reckon you can get a fully quipped oil cooler setup for £140
Old 28-12-2010 | 07:59 PM
left hooker's Avatar
left hooker
http://cgi.ebay.co.uk/SIERRA-SAPPHIR...item1c180b2f64
Old 28-12-2010 | 08:04 PM
It's Czech Mate's Avatar
It's Czech Mate
The simple answer to the OP is
a) What temps are you seeing on the road?
b) What is the operating range of temps of the oil you're using?
Without knowing a or b you just cant know what to do, despite the opining of some members.
If you do fit one, you may never get your oil up to the optimal temperature and then potentially shorten the lifespan of your engine
Old 28-12-2010 | 08:05 PM
Jon(M600BHP)
So no aeroquip ,no goodrich fittings, no remote filter, so its unfair to compare it
Old 28-12-2010 | 10:07 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Agree totally.
I was shocked when i asked Opie what was the correct operating temp of my oil. I certainly cannot reach it driving on the road & lets say i have driven very fast out there .
Old 29-12-2010 | 02:23 AM
Red16's Avatar
Red16
That ebay kit doesnt have a thermostat in the sandwich plate either!
Old 29-12-2010 | 12:11 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
I thought yours was a 4x4 kev, therefor you have a oil cooler? Unless you want to upgrade it maybe? But to what i understand you dont need to for a road car.
Old 29-12-2010 | 01:05 PM
NEIL A's Avatar
NEIL A
Kev i had one fitted to my old car, I had to due to the block and ended up blocking half it off as oil temps were too low.
Old 29-12-2010 | 04:31 PM
left hooker
from the ebay listing
In very cold/wet weather over cooling of the oil can be avoided by the addition of a thermostat built into the sandwich plate for£19.99 extra.
Old 29-12-2010 | 04:38 PM
cossiedave's Avatar
cossiedave
do the same job tho m8
Old 29-12-2010 | 05:04 PM
Jon(M600BHP)
Correct, just like a full on GGR breather do the same job as a Bailey £130 jobby
You pays your money you makes your choice
Old 29-12-2010 | 05:16 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Question about the one on eBay, It looks tall and not very wide. Is it the same shape as the standard cossie one?
mk22door
49
26-03-2022 08:15 AM
gcfcos
118
18-08-2015 06:53 PM
gordyshreds
20
10-08-2015 03:59 PM
COLEYST200
03-08-2015 09:55 AM
creator
02-08-2015 01:24 PM
