focus rs mk1 immobiliser help?
hi my focus has been sat up for 4 months and now wont start!
when i turn the key the fuel pump doesnt prime, is this the immobiliser?
battery is fine!
any help would be great
thanks kieran
battery is fine!
thanks kieran
Fuel cut off switch?not sure of the exact location on them,try near a kick panel etc.it's caught me out on kas a few times,can be people kicking the panel or banging something to hard so it maybe worth checking.
Also try the earths by the battery as these can become corroded over time.
If it is immobiliser the red light above the clock will be flashing when you turn ignition on. If the immobiliser is ok, the light will colme on for a few seconds with ignition, then it will go out. But if the immobiliser is cutting in, it won't turn over anyway.
Have you tried giving the top of the pump a tap while you try starting it?
massivewangers
30
01-10-2015 07:40 PM
