Focus lights flickering problem, please help
Old Dec 14, 2010 | 07:52 PM
bazzal's Avatar
bazzal
Default Focus lights flickering problem, please help
Hi all,
Got a weird and annoying problem with my 2000 focus zetec.
Basically all the lights flicker on it, headlights, rear lights, dash lights every light seems to flicker at exactly the same time, which makes driving at night
quite dangerous.
Also after it's been doing this for a minute or 2 all the warning
lights come on the dash, speedo needle shoots round to 140mph, and odometer reads just lines.
Has anyone had this problem on there focus or know what's wrong, as it's a little worrying when my missus and our little one are in the car.
Any help is much appreciated as always
Baz
Old Dec 14, 2010 | 07:54 PM
bazzal's Avatar
bazzal
Just to add the car seems to drive perfectly fine, no loss of power or anything,
Any help is greatly appreciated
Baz
Old Dec 14, 2010 | 08:00 PM
left hooker's Avatar
left hooker
my focus has had an earthing kit fitted to stop this
pee vee's Avatar
pee vee
if everything is doing it, then i'd make a guess at an earth problem,
and as it is all doing it at the same time, possibly the negative battery terminal, loose/ dirty/poor connection??
seems an odd problem for sure!
Old Dec 14, 2010 | 08:15 PM
RichieST's Avatar
RichieST
Flickering in time with engine RPM could mean alternator is on its way out...
left hooker
not that odd the original earths from batt to body and engine to body and engine to batt are rubish new conecting wires are needed like an earthing kit
Old Dec 14, 2010 | 08:20 PM
bazzal's Avatar
bazzal
No its not in time with the rpm's mate, just completely in there own time.
Old Dec 14, 2010 | 08:24 PM
vaughant's Avatar
vaughant
Battery/earth connections fella,there's a big block by the battery.check that theres no poor connections,corrosion,pure rust and so on.
Old Dec 14, 2010 | 09:32 PM
bazzal's Avatar
bazzal
Nice one mate I'll check all those bits in the morning, failing that any more suggestions
Old Dec 15, 2010 | 05:04 PM
bazzal's Avatar
bazzal
ok i had a mechanic check battery, terminals, altenator, all fine by him, so we're now stumped by the problem,
has anyone had this on there car and can tell me how to fix it, or whats wrong,
many thanks
baz
Old Dec 15, 2010 | 05:11 PM
stevos's Avatar
stevos
Mate i have got exact same problem with my st170 all lights seem to flicker every so often.i have yet to check my earths.
Old Dec 15, 2010 | 05:19 PM
bazzal's Avatar
bazzal
if you find the solution before i do mate please let me know, its bugginh the shit out of me, lol
RichieST's Avatar
RichieST
The smart charge will make the lights flicker slightly every now and then, normally when it's ticking over, you will see it flick very slightly 4-5 times. On the ST170, if the dash lights flicker, turn the brightness down slightly, that will stop it.
But the OP seems to be having more serious flickering so it must be something else!
Old Dec 15, 2010 | 06:06 PM
stevos's Avatar
stevos
Cheers rich mate you seem to be very knowledgeable with these cars.
Just bought mine from the inlaws and trying to iron out a few small stupid issues.
Old Dec 15, 2010 | 06:22 PM
jamie's's Avatar
jamie's
the early focus's had bad earth issues with the lights,
theres an earth connection behind a headlight(n/s i think)
the wires look intact but corrode in the terminal, cut the terminal off
and fit new 1, this usualy solves the earth prob,
tbh i dont remember it causing flickering but if its got a dodgy connection it could so worth a try anyhow
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
