Quaife seq gearbox in a cossie
enjoy http://www.youtube.com/watch?v=BwoiinVDq0g
id love a 3rd with one of these, gotta be a few quids worth
I sold my brand new 33g sequential box before i used it as i was told they were always going wrong and i didnt want to find out the hard way , and then and when the bloke used it quaife had put 5th and 6th the wrong way round ( good one ) and they then said ( after one outing ) that it needed a new 4th 5th and 6th as the dogs had worn and they bloody charged for it even though the box was brand new , what a service , not.
Thats without the 3dr
Yeh. Apparently theyre the only sequentil gearbox around these days that comes with a full instruction manual on how to repair and rebuild them yourself.
Martin @ MEF Motorsport plans to run one in his new E36 M3 engined 1series BMW rally car hes building once his C2R2 has sold.
Theyre made in Sweeden, but the guy is supposed to speak brilliant english and be very pleasant to deal with. ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
http://www.tractive.se/__10
Yep tracktive or elite. Keep off quaife they wear out for fun. Running to rally cars one with a new quaife lasted 12month about 12 rallys needed everything.the other had R+D did 2 half years about 35 rallys only reverse gear needed. Both drivers are kind on gear boxes.
Roosie, its a rwd gearbox, the car in the link I posted now runs one, its either running the Tractive or the Sadev in that clip though as I don't know when they changed the box.
Sadev I believe is not designed for massive torque although thats a 2.5 Millington in that Escort and its broken both a Sadev and Tractive box.
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
http://www.youtube.com/watch?v=mO-3OzAuiRE
Tractive 6 speed box and Shiftec system
![Much is the "Yo"](https://passionford.com/forum/images/smilies/ok16.gif)
What you need Rich is:
Tractive 6 speed box and Shiftec system![Much is the "Yo"](https://passionford.com/forum/images/smilies/ok16.gif)
Why does that shift so quickly and not need the clutch at all where as the others appear to need it?
I.e. What does the Shiftec system do?
With an integrated system like Geartronics, Shiftec etc. it works in conjuction with the ECU to cut the power to the ignition coil for a split second, which in turn obviously stops the engine making any power at that point.
In that same split second window, the loading is released from the dogs/dog rings and the sliding sleeves can move onto the next ratio and engage the drive through that as the ignition is powered again.
You can create the same 'load off' effect by lifting off the throttle as you change gear. Some people prefer to use the clutch on every change to try and preserve the lifespan of the gearbox.
On a sequential box you need to take the load off the dogs/dog rings to make the shift. Normally to release the load you dip the clutch and allow the flywheel to spin independantly of the input shaft.
Ah right, yes I've heard of that before.
So it's all down to the shifter? You could run that with the Quaife for example?
The gearcut in that clip is lovely, most likely a combination of fuel and ignition cut, plus with the paddle he's using the 'blip' function for the down change...
Systems for competetion get even tricker with active cuts being fed back from the GCU (gearbox control unit) to the ECU giving varying cut times. The better GCU's use a closed loop monitoring system to ensure you are in gear before releasing the cut....
![](http://img.photobucket.com/albums/v490/sibster/GeartronicsPic.jpg)
Geartronics stuff is excellent.
As Ian states - the closed loop technology allows for a much greater amount of safety to stop you over-revving the engine.
Quick vid on the tube of Geartronics:
http://www.youtube.com/watch?v=PD_DuTVbJAE
Hears another vid of a tractive being used with a geartronics system Running a 2.5 Millington http://www.youtube.com/watch?v=SRIQw01-1ic
I was recently having a chat with someone involved in that car and basically I hear they broke the Tractive and preffered to use the Sadev as unlike Tractive they were offered a spare box incase they had any issues.
I hear Simon can peddle a Mk2 rather well, certainly looks like it from his videos !
Well be aware if you break one you will get no change out of a grand to open it up, I believe the Sadev isn't rated power wise like the Tractive is but still your talking serious money to buy one let alone look after one.
PM'd
PM'd
Ah cool, I wouldn't know mate !
Yeah he can certinaly pedal. Seen him on the Jim Clark national rally this year. One of the fastest ml2 drivers around the now even including the irish men as he has beat them this year
Sounds like they got a good deal on the Sadev then. I think he was one of the 1st to use it in a mk2.
Being honest I hadn't heard of him until recently as I don't follow the sport that well, looks like I should though !
The Escort in the picture is a guys called Paul Alexander
Build thread is here, nice engine too !
http://www.turbosport.co.uk/showthre...647-Gp4-rS2000
TPM961
15-01-2018 10:50 AM
Tank Mike
Ford Focus ST Parts for Sale
18-05-2016 09:38 PM
Russ Payne
25-09-2015 08:29 PM
