HELP!!! MORE PROBLEMS!!
Old Jan 29, 2005 | 05:19 PM
rsjohn's Avatar
rsjohn
Default HELP!!! MORE PROBLEMS!!
On fitting my secs monitor today, im having problems with the map signal, i think i have a dodgy connection on ecu, anyway iv managed to sort that out but now the car wont start, it fires then cuts out, if i disconnect the wire from secs to pin 15 on ecu where its suppose to go the car runs ok.
Iv put the wire straight into the back of the plug could this be where im going wrong as the original wire joins to othersfrom pins 30 ans 11.
John.
Old Jan 29, 2005 | 05:31 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
11 is VREF Neg
30 is VREF Pos
15 is MAP Sensor Signal
Not sure if that helps mate?
Old Jan 29, 2005 | 05:36 PM
rsjohn's Avatar
rsjohn
so why when i connect the secs wire to pin 15 does the car not run??
John.
Old Jan 29, 2005 | 05:38 PM
PhilM's Avatar
PhilM
No idea mate, never seen how a SECS monitor is wired up!
Drop Simon a PM/Email/Call im sure he'll help you out when hes back at work on Monday
Old Jan 29, 2005 | 06:52 PM
rsjohn's Avatar
rsjohn
Anyone else had any problems when fitting secs monitor??
John.
Old Jan 29, 2005 | 08:05 PM
rsjohn's Avatar
rsjohn
Sorted now cheers.
John.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
