new work van
Old Dec 6, 2010 | 06:41 PM
dingla rs's Avatar
dingla rs
Default new work van
how much fun would this be
http://cgi.ebay.co.uk/ford-transit-m...item2a0c6b6820
Old Dec 6, 2010 | 06:44 PM
crumpet's Avatar
crumpet
What a waste of a perfect transit uning that Shit engine!
Old Dec 6, 2010 | 06:49 PM
danneth's Avatar
danneth
TORQUE!
* waits for chip to turn this into a 10 pager*
Old Dec 6, 2010 | 06:52 PM
crumpet's Avatar
crumpet
ive owned a c20let pal and i dont like them, Chips c20 engines are built properlly using good parts, fair play to him.He has experience with them and Yb's and many other lumps, il ask him which he prefers actually
Standard c20lets are shite imo, alot weaker than a cossie YB, plus a YB would of been a v easy swap compared to that c20let, mounts are the same and type 9 fits onto the block.
Old Dec 6, 2010 | 09:02 PM
S1rst's Avatar
S1rst
The C20LET is actually a VERY strong engine, especially in standard or mildly tuned form, so im not quite sure why you think otherwise mate. Unless you had a shitter of course. Ive had a few and all have been pretty much bullet proof.
Old Dec 6, 2010 | 09:08 PM
rapid3door's Avatar
rapid3door
tahts rude
Old Dec 6, 2010 | 10:01 PM
crumpet's Avatar
crumpet
they aint strong at all on standard rods and pistons, plus porous heads had to be helped out by cosworth hence the coscast,the rod bolts snap if you run above 20psi on a k16 then they stretch as i found out, the kkk16 turbos arnt very good, and iirc i dont think ive seen a standard c20let over a Genuine 300+bhp and last a while.
My c20let was built my chris astley and lasted 2k miles, apr rod bolts, new mahles, cometic 1.9mm, recon k16, xe inlet cam and adjustable pulley,eds ph2,actuator, tx Ł2 downpipe and exhaust, etc... lasted 8 days in my ownedship
Old Dec 6, 2010 | 10:11 PM
S1rst's Avatar
S1rst
Thats what i mean mate. If you had a modified engine built and it only lasted 2000 miles, then it obviously wasnt done right to start with. Thats not to say the C20LET is bad engine, but they'll always be a few that are not done right, or are 'over modified', and that goes for C20LET, YB or any other engine for that matter.
Oh and if i remeber correctly (its been a few years since i was into vauxhalls ) the porous heads are not a problem on the LET, that was only a problem on the XE's.
Like any engine really, if its maxed out or poorly done, it wont last long.
Standard, mildly tuned, or modified properly and within its limits and you shouldnt have much to worry about.
Old Dec 6, 2010 | 10:13 PM
crumpet's Avatar
crumpet
my head was porous too, and that was let pmsl.... Il never own another vauxhall!...you can talk anyway, you own a ford
Old Dec 6, 2010 | 10:35 PM
S1rst's Avatar
S1rst
Yes im sure some earlier LET's still used the GM head, but im pretty sure the later LET's and the majority had the coscast head. Sounds like you were one of the unlucky ones. Oh and i dont have a ford anymore, its even worse, i actually own a bmw.
Old Dec 6, 2010 | 11:14 PM
crumpet's Avatar
crumpet
Old Dec 6, 2010 | 11:49 PM
c20tbo's Avatar
c20tbo
Good for 300bhp all day long set of arp's and a decent head gasket, had one in a nova at that power with sccr box, did many track days a lots of road miles, all built at home never missed a beat and still going strong after 4yrs, turbos are shite though and the coscast is the one to have but early gm's can be repaired easily.
Great fun in a small vaux/ value for money, cheap/easy to built up to that bhp.
Old Dec 6, 2010 | 11:50 PM
crumpet's Avatar
crumpet
oh mine had arp head stud kit too, id be bored with 300bhp though, i wanted to rebuild mine and run a to4e, aim for 360-400 but its just too expensive
van_dogg_pavvy
Mar 3, 2016 09:30 AM
orion88
29
Feb 16, 2016 08:47 AM
S3an
Aug 11, 2015 07:26 PM
vdubo7
Aug 2, 2015 08:17 PM
