computer help
Old Dec 1, 2010 | 10:39 AM
Mark_'s Avatar
Mark_
Default computer help
my laptop keeps saying there is new updates to install,
ive tried to install them but everytime i turn it back on the new update icon keeps showing on the shut down button.
every time you shut down it tries to install but it fails. i tried it with my internet security turnt off but no joy.
im running windows 7.
is there a way to cancel the update and remove it to stop it doing the same evrytime i shut it down?
Old Dec 1, 2010 | 10:41 AM
RichieST's Avatar
RichieST
I know on XP you can go into the update page through the security centre and redownload any failed updates. ould be worth a try.
Old Dec 1, 2010 | 10:43 AM
Mark_'s Avatar
Mark_
cheers ill try it now
Old Dec 1, 2010 | 10:45 AM
GaryBean's Avatar
GaryBean
try doing the updates online if they still fail. turn the automatic updates of and it should be fine.
Old Dec 1, 2010 | 10:48 AM
Mark_'s Avatar
Mark_
i just did the above, it failed again.
i just looked at the review and it says its for windows xp, im running windows 7 so why do i keep picking it up?
its some sort of security update.
is there a way i candisable the update so it doesnt keep flashing up?
Old Dec 1, 2010 | 10:51 AM
Mark_'s Avatar
Mark_
this is what the update says............
Security Update for .NET Framework 4 on Windows XP, Windows Server 2003, Windows Vista, Windows 7, Windows Server 2008, Windows Server 2008 R2 for x64-based Systems (KB2160841)
Download size: 2.5 MB
You may need to restart your computer for this update to take effect.
Update type: Important
A security issue has been identified that could allow an attacker to compromise your Windows-based system that is running the Microsoft .NET Framework and gain complete control over it. You can help protect your computer by installing this update from Microsoft. After you install this item, you may have to restart your computer.
More information:
http://go.microsoft.com/fwlink/?LinkID=194969
Help and Support:
http://support.microsoft.com
ive tried to get it to install and it just wont do it.
Old Dec 1, 2010 | 11:28 AM
S1's Avatar
S1
Try downloading the package and then installing it. It can be found here - http://www.microsoft.com/downloads/e...displaylang=en
If you havent already got one create yourself a Setups folder on the C: drive and save it to there.
Old Dec 1, 2010 | 01:12 PM
collierm's Avatar
collierm
MP for K.I.S.S
Do a search for a file on your computer called update.log. Its where all the info about Windows Updates gets placed. Open it and look for the time when you installed the update. It should tell you a reason or error code why it failed.
Or you can check your event viewer, system log I think is where the info is also written. Start->Run->eventvwr and click OK.
Old Dec 1, 2010 | 02:05 PM
danb21t's Avatar
danb21t
+1
do this!
Old Dec 1, 2010 | 08:09 PM
Mark_'s Avatar
Mark_
ive changed the settings to allow me which updates to install,
cheers for the help, ill try all of the above tomorro
AJC
Oct 1, 2015 06:47 PM
Kam B
Sep 24, 2015 10:40 AM
Bailes1992
Sep 3, 2015 02:17 PM
