Actuators
Old Nov 17, 2010 | 06:30 AM
kiwikermit's Avatar
kiwikermit
Default Actuators
What is the difference between a -31 actuator and a -34 actuator?
Old Nov 17, 2010 | 06:36 AM
1223456's Avatar
1223456
that spring is stronger in a -34, I think the lowest you can set it is about 13psi but I may be wrong, -34 is usually used for higher boost engines, I changed my -31 for a -34. Worth giving cr turbo's a bell as thats what I did to make my decision
-31 has a stronger spring than the std one fitted to a T3, -34 is stronger still.
Old Nov 17, 2010 | 06:39 AM
kiwikermit's Avatar
kiwikermit
Cheers, I suspected that was the case... if i was after 18-20 psi i'm better off with a -34 rather than preloading a -31 heavily then.
Old Nov 17, 2010 | 05:02 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
......not really....i run 30 psi on a ut t38 using a -31 and would use a -31 on a t3-t4.....depends on what u want the car to feel like and ur tuners choice..........
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
