escos banana pod help
Old 15-11-2010 | 05:21 PM
skinnybalboa's Avatar
skinnybalboa
joel b
Default escos banana pod help
hey folks, needing some help please,
just bought a set of gauges to fit into my mk5 rs2000, would just like to know how to go about wiring up the gauges as they only have the pins sticking out of the back of them, im hoping someone will have a diagram of what the pins are for???
cheers joel
Old 15-11-2010 | 05:49 PM
FletchCossie's Avatar
FletchCossie
The two pin one is for the lights iirc. There is a connector, which comes off the clocks on an Esc cos and goes to the banana pod. I think two of the 5 pin one was earths, but can't remember which.
Old 15-11-2010 | 08:21 PM
skinnybalboa
joel b
ok im jst tryin to figure out how it will work as i only want to fit it if i can get all the gauges working correctly, my gauges have two wires from bulb to bulb so can only assume thats for the power and earth i can only assume this is because there was a fault maybe??!!, so only really need to figure out what the 6 pins do?
i will try and get a photo up to show you what i mean
Old 15-11-2010 | 09:48 PM
xr4x4rs's Avatar
xr4x4rs
the banana pod dials are powered by an incertor on the escos dash clocks as they dont have bulbs and im sure its something stupid like 100volts that goes through them
Old 16-11-2010 | 05:07 PM
skinnybalboa
joel b
heres a couple of photos, if anyone could point out what the pins do i would be very grateful...
Old 16-11-2010 | 05:19 PM
kjc300's Avatar
kjc300
Old 17-11-2010 | 04:36 PM
skinnybalboa
joel b
thanks very much for the diagram mate, ill have to show it to someone up here and see if they can translate it into baby terms for me to understand, electronics isnt really my strongest point thats for sure hahahaha.
i will just have to research which senders i need to get for the oil sender and turbo sender and then hope for the best!!! lol
Old 17-11-2010 | 05:43 PM
xr4x4rs's Avatar
xr4x4rs
the turbo works off vac pipe on the inlet
see that brass mesh thing in the middle, thats where the vac pipe connects to
Old 18-11-2010 | 05:39 PM
skinnybalboa
joel b
ok, to start off with i will have to track down the sender for the boost gauge and then the oil pressure sender then figure out what inverter i need etc then try to piece it all together...
gcfcos
59
06-10-2015 05:04 PM
Mickeystewart
09-09-2015 04:04 PM
Quick Reply: escos banana pod help
