escos fuel pump
escos fuel pump
correct me if im wrong but if you disconnect the fuel line at inlet manifold and turn on the ign the fuel should flow continiously as the pump trys to prime to set back pressure
correct ?????
correct ?????
thks for the reply mark ,
how does the fuel pump prime if its open ended, am i missing something.getting a fuel pressure rig to check that am but thought id look at flow to see if we have good supply to rail,car wont pick up on nrevs and will only start intermitingly
Remove the return line and put in to a can then you can measure return flow with engine running, But carefull running car with a open can.
Mark
mark ,
engine only runs with fuel feed disconnected ( really and for a few seconds only...lol)
with fuel line connected it wont start ?????
james ,
tryin to sort a buddy car .......escos
james ,
just to go back to my earlier q , should the pump run continuiously if open ended, surley it cant hit the pressure cut off setpoint if not dead ended ???????
cool , so what stops the pump running then,when ign is switched on like in my saff the pump runs and then stops after a few seconds.always thought it was on a pressure signal....
good to clear that up ,
have you ever seen a tps sensor disconnect light up the battery dash light.disconnected it while car was running (other car) to test therory on non running one......light has stayed on
JK12
33
26-04-2021 12:09 PM
