Alcon Monoblock 6 pot caliper
I need two of the bridge pipes but alcon dont list them for the caliper i have got anymore and my calipers are designed to take a 36mm disc and the normal are designed to take a 32mm disc so dont know if the pipes longer. as ived been told they are an actual wider caliper.
And want to know if the bridge pipe off your caliper will fit as these are still available.
Heres a pic of my measurements
![](http://i121.photobucket.com/albums/o230/gaz_b88/5559a52c.jpg)
Ived also got another pic from the outside of the fixing (at the end of the pipe) to the outside of the opposit one.
![](http://i121.photobucket.com/albums/o230/gaz_b88/626c683b.jpg)
It measured 145.95mm
Cheers martin
Cheers martin
![](https://passionford.com/forum/images/smilies/roi.gif)
could you pm me a price for 2x362/36 ap discs, 2 bells, 2 brackets and braided lines.
cheers martin
BUMP FOR MARTIN
Hiya martin i spoke to alcon and they said they carnt help and to go through jag for the bridge pipes but jag dont list the bridge pipes and say they carnt get them![Wall](https://passionford.com/forum/images/smilies/wall.gif)
If you could find time to measure the bridge pipe on yours like i have in the pics above and i will order them off the part munber for your caliper and get them fitted!
Could you also pm me a price for the above bells brackets discs ect!
cheers
cheers
On the caliper pictured, it needs ideally to have some means of fixing the pipe alongs it's length across the front of the caliper, they have been known to fracture pipes here.
Best bet is a hard setting sealant stuff like sikaflex.
Cheers martin![](https://passionford.com/forum/images/smilies/roi.gif)
Cheers martin
I have the ones that accept a 32mm disc and I'd say they're definitely wider on yours.
What car are you trying to fit them on as your going to need custom bells and brackets. Ap aren't going to have off the shelf parts for you.
1st to 200 without NOS
Sorry but it looks as if you've bought some calipers that belonged on a XKR. And have been messed around with.
did you get my pm martin?
155lee
24-10-2015 11:11 AM
