MS Excel - pivot tables help needed
I have two versions of the same spreadsheet that contain about 95% the same information, but one of them will have new additions or alterations.
I believe that a Pivot Table is the quickest way to find these new entries but haven't got a clue where to start!
Anyone able to offer a step-by-step guide?
Is there a unique indentifier for each row?
If so, the quickest and easiest way is to copy and paste both into one worksheet, one after the other, Select All, then:
- Data
- Filter
- Advanced Filter
- OK if it gives an error
- Criteria range - select just the unique identifier field
- Tick 'Unique records only'
- Ok
- Select all, copy and paste into new sheet, then you have your merged sheets.
HTH
Chris
- Data
- Filter
- Advanced Filter
- Ok
HTH
Chris
Chris
Thanks for this but I don't think I've explained properly - the method above has given me 18,440 unique records from 38,693 lines in the combined sheet.
The first version has 19,184 lines, and the second has 19,510 lines - its the 326 new lines I'm wanting to identify.
Oh ok, sorry I thought it was so you could create a merged spreadsheet.
You can try it in vba? Something like:
Haven't put it in to test and it's been a wee while so worth trying on a duplicate file first(!).
Chris
Code:
Dim a = "New Worksheet Name"
Dim b = "Old Worksheet Name"
Dim x = 1 //Column number for unique ID
With Worksheets(a)
for i = 0 to .Rows.Count
for j = 0 to Worksheets(b).Rows.Count
if Worksheets(b).Cells(j, x).Value = .Cells(i, x).Value then .Rows(i).Delete
end for
end for
end with
Chris
JoeyBoyden
Jan 4, 2024 02:36 PM
borboyous
Aug 22, 2015 11:17 AM
