anti lag and launch control, really worth it?
#42
Its much cheaper for existing customers to upgrade to of course, as you can see:
http://www.motorsport-developments.c...ecu_chips.html
#43
#44
It is indeed expensive, however, don forget with aftermarket you still need to pay to get it mapped and it VERY rarely runs as well as the OE kit with a decent cal.
Appreciated Stu, but of course you have to take in distance to account, and being 100% confident if KNOWING it's been fully mapped/setup and will be 100% safe.
Also then when aftermarket more people can map it, rather than having locked chips etc
You can also sell off your OEM gear to offset the cost.
I've been told mine will run perfectly, but I must admit my cold start before was lovely!
#45
Stu how long before this is availble for my FRS?
she's been retuired to weekends now, and antilag with launch control could make the sunday drives epic
#46
Totally agree, its always swings and roundabouts. As long as you get the end result that you want, with best future possibilities that suit your budget and expertise, at the best overall price then thats all that matters mate.
![](https://passionford.com/forum/images/smilies/roi.gif)
#48
His mk3 escort has what 600+ and 4x4 would launch control really be beneficial ? ????????
Anti lag Would be though and he has got it ain't he.
Is a marram shafted turbo a must for anti lag or can you run it mild without one stu?
#49
cossie fan (unluckerly)
#52
James, I have a 247 shafted T4, will your ALS work ok with a mountune tophat bypass valve?
#53
pm sent
#54
Standard turbos tend to be fine if the ALS is only used sparringly in road conditions, they will not take competition abuse of constant ALS.
Replied, I have now made that service clearer on my website as I guess you guys dont actually have crystal balls.
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
#56
thats ok if you want to go aftermarkt management, but then theres mapping ontop which is 500 notes, plus having the loommodfied to suit your engine which is more so after market management costs a hell of a lot more than cossie management with all the extras fitted to it, plus im trying to keep it all cossie stuff as all this stuff will be transfered over to the escos when it needs its engine
#57
Mapping will be required and it will more than likely be a live map which is way better than any off the shelf chip.
As for mapping costing 500 quid - it all depends who you know
#59
i can see what your saying, but i dont want after market management, as if something goes wrong down the line i have to take it back to the person who fitted it and mapped it, at east with cossie stuff 90% of the time people can fix problems with when its ecu related, and if the ecu goes down then its easily to get anbother to get you back on the road quicker, i know its unlikely for a new ecu to go down but it does happen
im quite happy to stick with l8 for the time being
#60
If you take it to someone who knows what they're doing, then use management they like, you won't go wrong. New ECU's come with something called warranty too
#68
cheers danny
#69
Yes Danny, it did. Detonation melted an exhaust valve and done quite bad damage to a piston.
I've spoken to Stu about this and we don't agree, so I chose not to bother responding to his last email, as I could see I wasn't going to get anywhere.
I know the engine was absolutely spot on before the chip change (12,000 miles), and only lasted a few hundred miles afterwards.
Anyway, you live and learn and we will never agree, so don't see the point in dragging it up. I've moved on and will choose who gets their hands on my car very carefully in the future.
#72
all off the shelf chips require a pro set up and check over, i dont really see how any one can be blamed apart the person who declaired your car safe for hard use tbh,
we would always be more than happy to tweek chips where its needed, sadly if we didnt see the car, there isnt much we can do.
did your wideband have a knock detector? and was calibrated? our wideband kit cost over £6k for good reason.
#73
cheers danny
#77
I wished i had spoken to Martin before I got my wasted spark and new loom made as I really should have gone for T6 then you get all the extras included in the ECU.
I really can't afford it now, but i'm pretty sure it'll go that way eventually.
Rich
Rich
