Intercooler Test (Pics added Page 10)
Old 10-11-2010, 08:52 PM
  #161
cossiedave
cossiedave's Avatar
Originally Posted by Martin-Reyland
We know that mine doesn't!
you dont need one then
Old 10-11-2010, 08:53 PM
  #162
DazF
Designer/Fabricator
DazF's Avatar
Originally Posted by cossie4i
First off a massive thanks must go to Pete and Darren of Spec-R for bringing there intercooler and helping to remove and fit all the coolers and rad
They also saved the day with a spacer to move the rad forward otherwise both the Spec-R and Airtec intercooer would not have fitted.
We started the day testing my original 50mm intercooler.
We had more power from the start today due to the Air Temp being 11 degress cooler than the last time my car was on EPs RR, this gave a bit more boost midrange.
Run 1 Start inlet temp of 26 and finish 42 Power 466.6bhp
Run 2 Start inlet temp of 27 and finish 43 Power 466.8bhp
Run 3 Start inlet temp of 29 and finish 42 Power 468.3bhp
Air temp was 11 on these runs with a intake temp of 15
Next we fitted the Spec-R intercooler.
Air temp was 15 on these runs with a intake temp of 19
Due to the 4i bumper being different to a 3dr we could not refit the bumper correctly, also due to the intercooler being thicker my oil cooler would not fit in the position i had it in so had to be cable tied to the car.
Run 1 Start inlet temp of 22 finish 36 Power 473bhp
Run 2 Start inlet temp of 25 finish 36 Power 476bhp
Run 3 Start inlet temp of 26 finish 37 Power 474bhp
We then done 3 runs with the bumper removed as due to it not fitting correctly with the Spec-R intercooler it was covering most of it up.
Run 1 Start inlet temp of 24 finish 27 Power 478bhp
Run 2 Start inlet temp of 21 finish 27 Power 480.8bhp
Run 3 Start inlet temp of 20 finish 26 Power 479.1bhp
It was noted that during the power run NO INCREASE of temp was noted, only when the throttle was shut did the temps rise.
We then fitted my Modified Airtec Intercooler.
I had different size pipes fitted due to the standard ones only having a inside diameter of 53mm, i had these changed to the same size as my original intercooler of 61mm inside diameter.
The bumper was refitted for these runs.
Run 1 Start inlet temp of 22 finish 27 Power 478.2bhp
Run 2 Start inlet temp of 22 finish 28 Power 479.4bhp
Run 3 Start inlet temp of 23 finish 27 Power 478.8bhp
Air temp was 12 and intake temp of 17.
With the Airtec intercooler fitted when the throttle was shut you could hear the air causing some turbo surge but the Spec-R intercooler did not do this.
It was a shame that we could not road test the car with the Spec-R intercooler fitted as im sure the inlet temps would have been even better on the road.
Also on my journey home the Airtec did not perform any better than my original intercooler with the inlet temp around 15 for both coolers. Also both seem to take a long time for the temps to drop if you have a bit of heat soak.
Will add more if i think of anything
Better thank Luke and Danny LOL
Steve
Glad we could be of service to you Steve
Nice to meet you and the guys at EP today.
Good results all round for you and your car today
The little mod/bracket worked well, and i will look at doing a different one for you this week to bring the rad back towards the front.
Thanks to Luke/Danny for the time on the rollers and thier crew for putting up with me borrowing tools
The Spec-R website is being revamped as we speak, and will be live hopefully by the end of the month.
Regards
Daz
  #163
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
hahaha, thanks
Old 10-11-2010, 08:56 PM
  #164
Danny @ Enhanced Performance
Danny @ Enhanced Performance's Avatar
It sounds like I know as much as you As you said that yours was between 38/42 didn't you? Anyhow I do know that at 200mph (the real test!!) my temps were below 40 deg so that's good enough for me.
Martin you asked me a question and i told you the answer,with throttle open when ripping around the track my best was 38 and my worst was 42 so atleast i know what and when my act where reached,now if i can get that down to 28-32 with a better flow then it will greatly improve things no end and as iv said i will prove it all soon..
If its a great improvement i will obviously say if it isnt i will openly say too,fucking hell its not my product so i wont benefit from all this untill i buy one and fit it to my car!!
cheers danny
  #165
J1mbo
B1mbo
J1mbo's Avatar
Originally Posted by Danny @ Enhanced Performance
Why did your dad build a more powerfull engine for then???because he could thats why!!!
This cooler is better for more reasons than just getting 10 hp jimbo so really mate as usual your missing the point!!!lol
In petes words on mad ades car they see alot more than 10 hp!!!and still with better temps also its more down to air flow and air speed...
What youve just said is like saying why put that much better inlet plenum on my car??although its far more efficient in flow etc it only makes 10 hp more so il just stick with my std one!!!!LOL
cheers danny
Danny I'm not thick
I'm talking about martins, and my dads car, they rant bloody race cars if they are seeing 40 degrees over a possible 35 do you think they would stop the car,sulk and pay Ł700 for a new one because it flows a little better and cools a little better ?
Like feck they would, their engines are safe, doing the numbers and doing the business, they don't need to change a thing !
From what I can see everyone is getting caught up on minor details here
Old 10-11-2010, 09:02 PM
  #166
Originally Posted by J1mbo
Danny I'm not thick
I didnt once say you needed one mate,i said you would benefit from one!!!!
any engine in the realms of the power your dads or martins is would benefit from one..
Iv got a pro alloy mate and as said it works but if i fit a spec r and its better then i havnt wasted Ł700 have i???
cheers danny
Old 10-11-2010, 09:06 PM
  #167
Martin-Hadland
cheers danny
How do you know that Danny? And what can I hope to see?
Old 10-11-2010, 09:07 PM
  #168
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Regards
Daz
As said it was very nice to meet you and Pete today
Thanks for looking into making me another bracket for the Rad.
And again thanks for all the help today, couldn't of done it without you
Steve
Old 10-11-2010, 09:08 PM
  #169
lawnsy
lawnsy's Avatar
Danny I'm not thick
Lower temps and Better flow with no surge....its not rocket science that it will give a smoother power graph and will only beneft the engine so why try to twist things.....
Old 10-11-2010, 09:13 PM
  #170
DazF
Designer/Fabricator
DazF's Avatar
Steve
No problem mate.
Pete will keep you informed.
Regards
Daz
Old 10-11-2010, 09:15 PM
  #171
I cant promise you anything martin but its been tested on a few cars now with great reults and if it proves to be better on mine then im sure it will on yours too..
Id be willing to let you try mine over winter if you like???
cheers danny
Old 10-11-2010, 09:16 PM
  #172
J1mbo
B1mbo
J1mbo's Avatar
I'll say again then, I'm talking about my dads car and martins, right now anyway
I'll ask Martin, does your car surge mart ? I know that awnser
I know my dads dosnt so what am I twisting ?
No surge then power is smooth all the way
We use a identical intercooler in car to the dyno
Would you like a graph to show just how smooth it is ?
  #173
wozzy
wozzy's Avatar
The thing is, if you lost 5 degrees act and managed to put a couple of degree in the map what are you going to gain ? Ten bhp ?
What use is ten bhp at 700 btw lol, on a fun track day which is non competitive
People get too strung up on getting the absolute late bhp out of the car it's too ott for me !
Were not race teams fighting for championchips lol
is that why all the MAD dyno graphs look so much better than the scc graphs???
Old 10-11-2010, 09:19 PM
  #174
bigchez
bigchez's Avatar
I see where martin and jim are coming from though - they know theirs are working (as Martin said less than 40 @ 200 is clearly working ) so without also testing theirs cannot say conclusively their i/c's are worse.
  #175
Nash
Cake lover!
Nash's Avatar
IMO the figures cannot be classed as fair as the test wasn't the same all the way through. The bumper makes a massive difference on air flow does it not? So surley you have to take the results for the spec R with the bumper partially fitted, not removed?
The test on the original 50mm Radtec Vrs the Airtek is a fair one though.
I do find it very interesting when new tech comes out and the improvements over the older tech.
Old 10-11-2010, 09:20 PM
  #176
J1mbo
B1mbo
J1mbo's Avatar
More than likely, scs graphs are mint though
There is always a safety margine in engine mapping this is what I'm talking about
Old 10-11-2010, 09:22 PM
  #177
Martin-Hadland
cheers danny
That's a nice offer Danny but I'd rather compare them in warmer temps tbh. I'm actually very pleased with my Pro Alloy cooler.
Haha my car does have surge, it just has relentless surge forwards Lol!!!!
Old 10-11-2010, 09:23 PM
  #178
lawnsy
lawnsy's Avatar
Thing is the info has been posted up to help people on pf just like it used to be....But now you get people like jimbo jumping on every post looking for faults because of who his dad is...
I am currently building a 500bhp engine using euan's old t4 and im looking at new intercoolers so this info might not be much use to martin or jimbos dads car but to me it helps me make a decision...
Old 10-11-2010, 09:26 PM
  #179
wozzy
wozzy's Avatar
only messing. Honest question now though for you and martin. Would you look into fitting this new intercooler if sheady HADN'T helped develop it??
Old 10-11-2010, 09:28 PM
  #180
J1mbo
B1mbo
J1mbo's Avatar
I don't jump on every post I just pick up on different points and put questions out there
It has nothing to do with who my dad is, I hate that
Its to do with me learning ! (bit like yourself ? ) If I wasn't tarred with the " his dad owns scs" brush you wouldn't be having a go right now, you'd see me trying to learn,
If that's ok ? I like to see everyones point of view
If you don't like by posts there's is a block button,
Jeez
Old 10-11-2010, 09:29 PM
  #181
Martin-Hadland
Thing is the info has been posted up to help people on pf just like it used to be....I am currently building a 500bhp engine using euan's old t4 and im looking at new intercoolers so this info might not be much use to martin or jimbos dads car but to me it helps me make a decision...
It doesn't really help you make a decision unless you were only considering the coolers tested!
  #182
Your welcome when its warmer too then???lol
cheers danny
Old 10-11-2010, 09:30 PM
  #183
J1mbo
B1mbo
J1mbo's Avatar
I don't think It has anything to do with marks involvement of developing
I think it's to do with why change something at works perfectly ?
But I would like one on my saff just too much money for me right now, so sticking with gen 500
Old 10-11-2010, 09:32 PM
  #184
Martin-Hadland
I'd only fit one if it gave decent improvements over my current set up, Peter can fit one to my car and do back to back tests if he wants......
Old 10-11-2010, 09:38 PM
  #185
NEIL A
NEIL A's Avatar
Sounds like a good test was carried out , Its just a shame there wasnt more coolers tested as it looks to be one of the cheapest on the market against the most exspensive.
Old 10-11-2010, 09:40 PM
  #186
wozzy
wozzy's Avatar
thanks for answering
Old 10-11-2010, 09:43 PM
  #187
B13 JUS
B13 JUS's Avatar
I forgot to thak B13 JUS for allowing us to use his Spec-R intercooler
Thanks mate, it looks a bit 2nd hand now lol
Steve
No problem at all mate.
I wonder if pete will sell it to me as second hand? Must be worth Ł600 now? Lol
No he said he's going to repaint it so it looks new again.
Old 10-11-2010, 09:45 PM
  #188
cossie4i+
TT T38 Power
cossie4i+'s Avatar
It was just a personal test for me between my old intercooler and the Airtec one i bought and modified
I was offered the chance to also test the Spec-R one which i did.
Steve
Old 10-11-2010, 09:46 PM
  #189
james kiely
james kiely's Avatar
Ł700 does sound expensive i suppose ,but someone has to pay for the development of new products i suppose .its probably time for the competition to step up and improve on what spec r have achieved which in turn will bring the prices down to a more affordable level for us all.
Old 10-11-2010, 09:48 PM
  #190
lawnsy
lawnsy's Avatar
I can see what you mean but it is good info for what coolers are working at that power level as thats what im aiming for plus there will be his old pro alloy cooler compared to his new spec r when its done and hopfully he will post the results up so we can see how good it performs against a good quality cooler...
I already have a rs500 cooler on me car but the only markings i can find on it is ( AHF 044 ) so unsure what it is but would rather have all the right bits on when it goes to be maped rather than finding out it needs more bits changing to get the best out of me car....
I know you would prob not benefit much from it but people like me would, Thats all i was trying to get across...
Old 10-11-2010, 09:50 PM
  #191
NEIL A
NEIL A's Avatar
Wasnt ment as a dig Steve ,but would be good if one of the mags did a full test of all the coolers like they did years ago.
When I changed my coolers to Bell bar and plate type ,i did a similar back to beck test on the road and got the same sort of results with boost increase,quicker recovery and lower temps.
Old 10-11-2010, 09:52 PM
  #192
J1mbo
B1mbo
J1mbo's Avatar
Ah fabrications I guess, adamski knows them guys well would be able to tell you if it's a recent one or older spec I imagine
Old 10-11-2010, 09:54 PM
  #193
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Im off to bed, im sure this will still be going on tomorrow lol
Steve
Old 10-11-2010, 09:55 PM
  #194
lawnsy
lawnsy's Avatar
This is the quote i felt you were been non constructive as you were not trying to learn like you said .....
Not trying to put you down jimbo its just how your post came across....
  #195
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Originally Posted by BRAMMER
Rod get to fuck, this is an internet forum if you want to give lessons on motorsport and all the other bollocks you chant keep it in the MAD tea room.
What at my age id sooner have another potato on my plate.
  #196
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
ahf sounds like " ah fabrications " lawnsy
same as what wenny was running in the mk 3 mate
i know as its currently sat in me kitchen as hes loaned me it for mock up on the s1 lol
beef
Old 10-11-2010, 09:56 PM
  #197
Sonic Boom
Sonic Boom's Avatar
How thick is the Spec R Intercooler?
Is it a direct fit or have you got to mess around moving the rad?
Rich
Old 10-11-2010, 09:58 PM
  #198
J1mbo
B1mbo
J1mbo's Avatar
Yeah may have got a bit carried away, but I stand by that still as it's my opinion, may have just came across a bit strong ?!
  #199
lawnsy
lawnsy's Avatar
Thankyou for the info .... It will be a old one as ive had the car nearly 5 years and i know it was on a good while befor that.....
Old 10-11-2010, 10:00 PM
  #200
RONNIE AMIS
RONNIE AMIS's Avatar
hopefully this wont turn in to shit. was an interesting thread. nice to see the results
Quick Reply: Intercooler Test (Pics added Page 10)
