24v BOA Cosworth not starting
Old Oct 23, 2010 | 07:47 PM
capriman's Avatar
capriman
Default 24v BOA Cosworth not starting
Hello I've just completed installing a BOA cosworth v6 in my 2.8 capri. I had the engine loom modified by Caprisport and have wired it in as per their instructions, came to start her up today for the first time and Iam not getting any spark, just wandered if anyone has any ideas, I have double checked all my connections and have good earths. Can the EDIS module be checked in any way? thanks
Old Oct 24, 2010 | 07:10 PM
mark_24v_wiring's Avatar
mark_24v_wiring
Make sure you have 12v+ at pin 8 of the edis, black wire on the coil pack plug and if you still have the plug for the kick down switch one of those should be 12v too, then check pin's 37 + 57 on the ecu for ignition live and pin 1 for perm live.
ECU pins 20,40 and 60 should all be earth
Let me know how ya go
Old Oct 25, 2010 | 06:46 PM
capriman's Avatar
capriman
Mark, many thanks for the advise, I'll check it out and let you know. cheers again Ian
Old Oct 25, 2010 | 06:58 PM
capriman's Avatar
capriman
Just done a quick check on the EDIS got 12v power, but nothing on the coil pack black wire, so must be the supply to that ? will have more time to check it over properly at the weekend. Cheers
Old Oct 25, 2010 | 07:55 PM
chaffe's Avatar
chaffe
Turbocharging Technician
yes mate! the coil pack black has to be 12v live to work 100% sure of that, no power there means no spark!
Old Oct 26, 2010 | 03:43 PM
mark_24v_wiring
As above no power there no spark
Old Oct 26, 2010 | 06:51 PM
capriman's Avatar
capriman
Thanks chaps ive just had her running, bit of a silly error really, I had forgotten to join the original capri ignition coil feed when I took the balast resistor out.!!! Only a couple of minor probs, a metallic noise like the cam chain rubbing on the cover, could this be oil pressure ???? I had the covers off for re-painting and uses boost performance gaskets so should be correct clearance, also the rev counter is not working - hopefully I can sort this easily. Appreciate all your good advise.
Regards Ian
will post a photo when I can work out how to do that !
Old Oct 26, 2010 | 07:44 PM
chaffe's Avatar
chaffe
glad to hear you got her running mate, got mine running on fri for the first time too! should be mechanicaly quiet though mate not sure what the problem is there?
Old Oct 26, 2010 | 08:11 PM
phil robson's Avatar
phil robson
would like to see some pics of this project
Old Oct 27, 2010 | 05:05 PM
mark_24v_wiring
Was the car a v6 to start with? if not do you have the v6 rev counter in place?
The only way that may work is to use this;
http://trigger-wheels.com/store/contents/en-uk/d31.html
You want the item second from bottom of the page will only cost £14.99 + a bit of post.
If you try it let me know as i have a capri to do just before christmas and it will mean i can just order it and not worry
Old Oct 27, 2010 | 05:19 PM
capriman's Avatar
capriman
Thanks for that, yes car was originally injection special '85 but I have changed the instruments a couple of times apparently early 2.8 rev counters don't run EDIS,my currnt one is off a series 1. will look for later type or use your suggestion thanks. Also decided to replace the timing chain and tensioner, think mine is well worn out / stretched.
Old Oct 27, 2010 | 05:36 PM
capriman's Avatar
capriman
some pics in photogallery... more to follow
Old Jul 21, 2015 | 11:08 AM
Lewisboa24v's Avatar
Lewisboa24v
Default Need help
Got problem,
Sum light would be so much appreciated !
Picked up Granada cosworth running boa,
On k plate
NO KEYS ,
I have ignition lights on ,
12v to coil pack
12v to kick down
12v to edis module (3 green wires) (coil pack )
6v to pin 8 on edis
12v to pin 1ecc
12v to pin 37&57 ecu
No spark ??,,
Only turns over if crossed starter,
mk22door
49
Mar 26, 2022 07:15 AM
Aug 14, 2015 07:29 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
