oiltemp on FRS-09
oiltemp on FRS-09
Hi all,
I bought a new Focus RS last year and i love it, but lately i've been having a small problem with it wich the dealer can't solve.
Sometimes the oil-temp gauge stays cold, while the coolant temp is normal. Even after driving 30min.
This continues for a few days and then suddenly works fine again, in some cases followed by an engine warning light.
The problem can be gone for months, or happen twice a week.
I found out last week that the fan is constantly on (even at cold start), when the problem occurs and it seems like the engine is not very warm when driven normally (I can touch the head after driven for 30 min.)
The mecanic told me te FRS doesn't have a separate oil-temp sensor, and this value is calculated, so it can't be something simpel as that. Anybody know if this is true?
The only error-code they get, is a comm. fault, his laptop doesn't give a solution for it. (so basically they can't do a thing )
Anybody got an idea where to look?
And how can it be the coolant gauge is normal, but the fan is on the whole time and the block is cold (estimated 40-50deg.C)?
Also, does anybody know if my car has a separate oil-cooler?
Thanks, Bas
Thanks, Bas
Will it ever end !!!!!!!
As for telling you they dont know what is wrong and go away is a joke - go elsewhere is my suggestion
09 plate = still in warranty = get main dealer to worry about it.
Remember - you can go to any Ford main dealer to rectify problems not just the one that sold you the motor.
Yes, it is under warranty.
I took it to 2 different main dealers already and both say the same.
I know it's not my problem or responsibility, but was hoping someone on here has some knowledge of the Electronics.
There are more people on here with a new RS, so someone might have had the same problem and a solution and save me a lot of time.
I’m also curious why the oil-temp gauge doesn’t seem to have it’s own sensor. Kind of useless then, I would think?
Thanks, Bas
Thanks, Bas
Fan constantly means a MAJOR fault has been logged, comms issue means the compy and ecu are ignoring each other, as not communicating, may be ecu fault, may be just a broken wire, or anything in between, defo get on the phone to ford technical if it's running very cold all the time it will not be doing it any good, try and coax a loan car from the company while they look at yours, then only give back the loan car when your car is finally fixed, or contact watchdog, auto express or similar if still no joy.
First try another dealer, and ask for it to be looked at, ask for a courtesy car and say you don't want it back until fixed.
If the dealer is unhelpful/can't fix it then call ford customer services, number is in the handbook.
I can't think off the top of my head any rs specific concerns, however you could have an aircon fault which is why the fan is constantly running.
The car will be going back to the dealer next week, so fingers crossed they fix it this time.
The trouble is the fault is not constantly there, so already twice i've picked up the car and me/they thought they fixed it, only to have the same problem a few weeks later!
Fan constantly means a MAJOR fault has been logged - Ok, so some form of safety feature then. Good info this.
may be just a broken wire - this or a faulty connector is what they suspect now.
I had a chat with the manager and they will suply a loan car for the time my car is there, so no problems there.
I will keep you posted.
Regards, Bas
You sure the air con isn't on, or the fan selector isn't set to windscreen? I know on the early focus's, this will automatically turn the a/c, thus the fans on.
But as you say, it should have an oil temperature. My ST gets to about 1/4 on the coolant temp gauge before the oil temperature starts to move, and it is at full temperature within 10 mins of driving.
