YB Timing
Old Oct 2, 2010 | 09:14 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Default YB Timing
What part of inside the dizzy has to be lined up with the contact?
There are two pointy bits that make contact, which one has to be set on tdc. Sorry if this is obvious..
If anyone has a pic it would help a lot
Old Oct 2, 2010 | 09:55 PM
James @ M Developments.'s Avatar
if you look at the outer ring on the dizzy body you will see a small scribe line, you may have to clean the dizzy to see it, but its where the plastic flash sheid sits there is also a dot mark on this flash sheild at the same point.. (off the top of my head bearing in mind im sat at home with a glass of wine, the scribe is at around the 2-3 o`clock area, if the dizzy is correctly fitted) the rotor arm center will point to this scribe mark.
The phase sensor lobes do not relate to tdc at all.
Old Oct 2, 2010 | 10:08 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
cheers, so because i had fitted the wasted spark and removed the dizzy cap, i'll have to refit the rotor arm to align it. Dont think my distributer timing pulley lines up with its mark, someone must have fitted it wrong before
Old Oct 2, 2010 | 10:11 PM
youdont have to fit the arm, but its the easiest way to explain it, there is a lug in the center shaft, that will also alighn with the scribe mark
Old Oct 2, 2010 | 10:40 PM
SS1's Avatar
SS1
This thread may help you
https://passionford.com/forum/ford-s...ing-marks.html
Old Oct 9, 2010 | 09:06 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
right, when timing it up should the cam pulleys sit in line naturally. I have to hold both mine with a spanner the keep them in place is this normal?
Old Oct 10, 2010 | 08:43 AM
BIG WULL's Avatar
BIG WULL
Fae the Dale
can anyone give me a clue with this, dont know if thats normal?
Old Oct 10, 2010 | 09:02 AM
There will be some willingness for the engine to try to turn due to the valve springs acting on the lobes, sometimes you do need to hold very gently, as it's right on the rock point of some valves/springs.
Old Oct 10, 2010 | 06:16 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
sweet thats alright then cheers
Old Oct 10, 2010 | 06:35 PM
botters's Avatar
botters
competant bodger
i find the cam pointers never perfectly point to each other anyway they are usually pretty close but not perfect
Old Oct 11, 2010 | 07:31 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
NOW someone tells me
Old Oct 11, 2010 | 07:39 PM
They aren't ever 100% perfect, just get as close as the belt pulley allows, when the block and or head has been skimmed and the distance between the cam pulleys and crank pulley shortened the crank and cams don't line up perfect either!!
Old Oct 11, 2010 | 07:42 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
i'd make the simplest of jobs difficult eh
Old Oct 11, 2010 | 08:49 PM
Anyone who has a gf/wifey knows that feeling!!
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
