Mk4 Fiesta Key
Yes no problem at all, if it is the square type key as I suspect it is, then can get most places, as you mention red it's obviously a coded key, ford dealer should be able to sort this from reg number on a mk4 fiesta, if not they can certainly supply and code a new red key so you can get the black ones easy and code yourself.
Shop around a lot I had 1 red master, and 1 black key all coded up with the old black key codes already stored deleted(previous owner had these) so ended up with 1 red 2 blacks(inc original one) for £58, some ford dealers wanted near £200, I used Abbyegate in Wymondham, Norfolk.
NC53
13-09-2015 03:05 PM
