Secs monitor help
Old 28-09-2010 | 01:40 PM
J1mbo's Avatar
J1mbo
B1mbo
Default Secs monitor help
Secs monitors, which way up do they go ! Gyre big plug with 5? Wires, does it go at the bottom or the top as I'm bonding it inn tonight and want to get it right !
Old 28-09-2010 | 01:48 PM
Isaac.Hunt's Avatar
Isaac.Hunt
This is the correct way up:
Old 28-09-2010 | 03:50 PM
J1mbo's Avatar
J1mbo
B1mbo
Thank you greatly don't suppose you have a wiring diagram for them do you so I know where to put wires in the loom ?
Old 28-09-2010 | 04:00 PM
JamesH's Avatar
JamesH
Jimbo,
Email address and I'll send over the manuals
Old 28-09-2010 | 04:04 PM
JamesH's Avatar
JamesH
Sent them to your email on your profile on here
Old 28-09-2010 | 05:16 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
jimbo have you got the right connector for it?? the right connector only goes on one way. I got a load of the connectors when i made a loom up for someone and it would only go on one way which is what you want really.
Old 28-09-2010 | 06:08 PM
Isaac.Hunt's Avatar
Isaac.Hunt
The trouble I had with mine is that I didn't have the original wiring loom so I had to make my own, although I used mainly the same colours as the original loom, my loom is not exactly as the original.
Using the photo (and numbered pins) from my original reply, the wiring is as follows:
[Connector 3]:
Pin #1: +VE, alarm LED
Pin #2: +VE, water injection
Pin #3: -VE, alarm LED
Pin #4: -VE, water injection
[Connector 4]:
Pin #5: Not used
Pin #6: Not used
Pin #7: Not used
Pin #8: Not used
[Connector 2]:
Not shown on photo but connector is for the two control buttons
[Connector 1]:
Pin #9: -VE: ECU Pin #1 (black)
Pin #10: +VE: ECU Pin #20 (red)
Pin #11: Not used (n/a)
Pin #12: Switched Ingnition +VE: ECU Pin #25 (orange)
Pin #13: TPS: ECU Pin #17 (green)
Pin #14: Coolant Sensor: ECU Pin #29 (blue)
Pin #15: ACT Sensor: ECU Pin #31 (yellow)
Pin #16: MAP Sensor: ECU Pin #15 (white)
Wire colours are in brackets, although as I say, I made my own loom so wire colours may not be identical to the original loom but as far as I remember they followed the original colour scheme quite closely.
Old 28-09-2010 | 07:15 PM
J1mbo's Avatar
J1mbo
B1mbo
Cheers guys been a great help
Yep sure have and yes it goes on one way I was asking which way up the screen actually went lol
pabloXR
21-09-2015 01:42 PM
Roscopeco
14-09-2015 06:32 PM
Bailes1992
03-09-2015 03:17 PM
K42L
28-08-2015 02:23 PM
Bailes1992
16-08-2015 08:14 PM
