HTC Desire question
HTC Desire question
A mate of mine has a HTC Desire - He's dissappointed with the battery's performance, and reckons if he leaves 3G on (apparently you have to turn it on and off when you don't need it???) it kills the battery in 4 hours.
Is this normal or should he be taking it back to the shop?
..BS Motorsport..
how often has he set his sync to happen? if its polling his email servers every 5 minutes over 3g I should imagine it would sap the power. By the sound of it unless hes turning off mobile networks for data its staying connected full time which 4 hours use is about right. Battery life does get better after 2-3 weeks of using it which is strange and I cant think of any reasonable reason? When I first got mine it would just last a day, now it lasts from friday night to monday morning with reasonable use.
ELASTIC BAND
I suspect something else is accessing the net, running in the back ground.
Not got a clue about android, but is there a task manager app of some sort, so you can see everything thats running.
send him in this direct, for a lot of searching and brousing,
http://forum.xda-developers.com/forumdisplay.php?f=594
Also a full reset and upgrade to the latest version of his OS will probably do wonders
Mine lasts 12 hours no problem and thats with wifi and 3g on. if you spend a lot of time on the net then it starts to cane the battery. I have Advanced App Killer installed and that helped the battery life
saff is working!!!...atm
was one of the reasons why i payed for a i-phone4 instead of getting a free desire.....my i4 lasts 2 days using it on the net at work (3g) and wifi at home.....
