is it worth going aftermarket over P8 Pectel
Old 25-09-2010, 10:51 PM
Roosie
500bhp Cosworth in making
Roosie's Avatar
Default is it worth going aftermarket over P8 Pectel
My fiesta cosworth is running with P8 (pectel board) 400bhp would it be benificial to run a aftermarket ecu like DTA?
Old 26-09-2010, 10:56 AM
Wouldn't make a difference imo so long as it's mapped correctly, could go K6 with launch traction etc, might as well do a power run just to check all is ok fuelling wise with what you've got as it's having problems already.
Old 26-09-2010, 11:55 AM
RS500/364
RS500/364's Avatar
the only reason i would change is because the P8 8inj i have can not ignition advance enough to give the extra power ! like another ecu
Old 26-09-2010, 12:14 PM
GARETH T
GARETH T's Avatar
unless you want to map it yourself, or you want a specific tuner to do the mapping (and he cant map p8) then its not worth making the jump IMO
arkeye
Ford Focus ST
20-02-2016 01:22 PM
tankybaby66
06-02-2016 02:24 PM
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
Oranoco
12
02-10-2015 02:18 PM
jay030787
25-09-2015 01:38 AM
Quick Reply: is it worth going aftermarket over P8 Pectel
