zetec lump
Old 25-09-2010, 06:11 PM
si20vturbo
si20vturbo's Avatar
Default zetec lump
hi just wondering if anyone knows what box will fit on the mondeo zetec lump to make it rwd as its going in my kit car? cheers
Old 25-09-2010, 07:02 PM
Dlatch!
Dlatch!'s Avatar
type9 sierra/cortina/escort fits straight on
ps www.locostbuilders.co.uk
Old 25-09-2010, 07:04 PM
Just make sure the type 9 is not a V6 type 9, as these have a different input shaft(longer).
Old 25-09-2010, 07:09 PM
Garage19
Garage19's Avatar
Type 9, MT75 or T5.
I've fitted the later two. MT75 needs a modified release bearing. T5 needs a new flywheel.
Old 25-09-2010, 08:18 PM
si20vturbo
si20vturbo's Avatar
iv got the type 9 box and the starter is in the wrong place
Old 25-09-2010, 11:16 PM
Dlatch!
Dlatch!'s Avatar
which side is it mounting on ? (when looking at front of engine) should be on the right handside
not sure on the difference in bell housings but any from a pinto powered ford will do the job
what kitcar is it going into btw?
Old 26-09-2010, 03:52 PM
si20vturbo
si20vturbo's Avatar
when looking at the front of the engine it is on the top left and on the box it is on the bottom right and it is going in a robin hood kit car
Old 26-09-2010, 04:35 PM
mark_24v_wiring
mark_24v_wiring's Avatar
When fitting a type 9 to the back of a zetec the starter location changes from std zetec position to the pinto position you will then find that 1 bolt hole from the type 9 wont do up as there is nothing there to bolt it to.
2 things you need to make life easy is the 1.8 escort flywheel that is listed on retro ford
http://retroford.co.uk/retro-shop/pr...products_id=93
Its been re-drilled to accept a pinto clutch or you could re-drill your own 1.8 escort flywheel if you have one.
and the spigot bearing
http://retroford.co.uk/retro-shop/pr...roducts_id=209
Did all this to a mk1 escort over the last month so i know it all works as it should do
Old 26-09-2010, 04:59 PM
si20vturbo
si20vturbo's Avatar
is there 2 types of zetec lumps then because there is no way to move starter on this lump that i have the only thing i think i can do is find some one that modifies the bell housing for the type 9 box?
mk3ste
17-10-2021 10:09 AM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
SMILER258
28-09-2015 09:04 AM
mondeomark
28-09-2015 06:28 AM
focuspower
20-09-2015 03:51 AM
Quick Reply: zetec lump
