water runing through turbo's?
12-09-2010, 12:33 PM
ZETEC TURBO
as above is it really needed as am unsure if to do it or not on my zetec turbo (gt30)??......
thanks G
12-09-2010, 02:19 PM
plenty of people running them without the water feed on YB engines. it helps the cooling system alot.
not sure on a zetec tho
12-09-2010, 02:45 PM
ZETEC TURBO
all gt turbos need watercooling, its easy to plumb them in
12-09-2010, 02:53 PM
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
The GT core 100% needs water cooling mate - the GT series of turbos don't have the same volume of oil flowing through them and so can't absorb the heat sufficiently.
12-09-2010, 02:57 PM
Yes a gt30 will need water cooling. Having a turbo cooler will help alot with water temps so would recommend one.
12-09-2010, 02:59 PM
my bad, didnt know the GT's had to have water feed
12-09-2010, 03:07 PM
so is it fine to remove the water pipes from the T series turbo's?
12-09-2010, 03:11 PM
t3s, t34s can run fine with no water cooling
12-09-2010, 04:09 PM
ZETEC TURBO
best get it done then thanks fella's !!!!!!
12-09-2010, 04:10 PM
Quote:
Originally Posted by
Mike Kerbey
it not cause any problems ? i know the water system will obviously run alot cooler...
JK12
33
26-04-2021 12:09 PM
xrmalin
13-09-2015 06:52 PM
turbowag
03-09-2015 08:07 AM
Jerry Ryan
02-09-2015 08:02 PM
