Saph Cos ABS fault finding?
My ABS light keeps flashing on and off on ym 2WD saph, sometimes staying on for quite a while. Is there anyway of fault finding on them?
I know on the old toyota avensis you can bridge across the fusebox and find the fault codes through a flashing led. Anything like this on the Cos?
Mart
Mart
Do you know anyone with the same car ? If so try plugging their ABS ECU in. I spent ages testing sensors and wiring on my old Saph before discovering the ECU was knackered
2wd and 4x4 ecu's Are different.
I had a prob same as you and it was the connectors that go to the front sensors located in engine bay near engine mounts,they were gunked up with oil and muck, cleaned them all fixed. if not try this link, is quite usefull...
http://bbs.rsownersclub.co.uk/showth...threadid=62939
DixieTheKid
23-07-2023 10:16 AM
slammedorion
15
01-11-2015 07:17 PM
