Solution for binding brakes?
Old Aug 29, 2010 | 08:00 PM
Big-Dan's Avatar
Big-Dan
Default Solution for binding brakes?
My freshly refurbed calipers are binding on 30kgs, I've bled the brakes twice over now so I know for sure it's not due to air or a twisted hose etc.
The chap at my local MOT station said that he cannot pass the car while the brake are like they are. Do they just need bedding in? The disks and pads are the same items that were removed from the car before the calipers were refurbed.
Any ideas? Obviously I want them to be safe as I have my little lad in the car with me when I have him over.
Big-Dan.
Old Aug 29, 2010 | 08:07 PM
P_is_for_Paul's Avatar
P_is_for_Paul
Coldo loves seamen
Plenty grease on the carrier slides?
Old Aug 29, 2010 | 08:11 PM
Big-Dan's Avatar
Big-Dan
Yes mate, I spread it all over like I was making a sandwich with the stuff.
Big-Dan.
Old Aug 29, 2010 | 08:16 PM
P_is_for_Paul
Coldo loves seamen
Big-Dan.
That's the only thing I could think of, that's what caused mine to bind on, which warped the discs!
Old Aug 29, 2010 | 08:20 PM
Big-Dan's Avatar
Big-Dan
I see. How little copper grease did you have on there? I'm thinking about just lathering it on, might even grease the disks, they won't bind on then
Big-Dan.
Old Aug 29, 2010 | 08:34 PM
P_is_for_Paul
Coldo loves seamen
Big-Dan.
None at all! I bought a big brake kit second hand and the carrier slides were bone dry. When I fitted the kit it turned out the discs were warped also, caused by the brakes binding. Put new discs on and it's great now
Old Aug 29, 2010 | 08:49 PM
Big-Dan's Avatar
Big-Dan
I'm pretty sure my disks aren't warped though, can't understand why they are binding on, doing my fucking swede in to be honest now.
Big-Dan.
Old Aug 29, 2010 | 09:15 PM
left hooker's Avatar
left hooker
did you clamp the pipes when you did your refurb might have crushed the pipes or a seal in the caliper is sticking/fitted wrong
how easy is it to spin with the wheel off
Old Aug 29, 2010 | 09:16 PM
Big-Dan's Avatar
Big-Dan
Anybody else have any suggestions?
Don't fancy handing any more money over to the spanner man unless I really have to.
Big-Dan.
Old Aug 30, 2010 | 06:56 AM
STeve's Avatar
Super Moderator
if calipers and discs are known to be good ,then the above post of possible pipe failure is a good one,I take it before the change everything was fine
Old Aug 30, 2010 | 07:05 AM
Elwood's Avatar
Elwood
I'm pretty sure my discs aren't warped though
Have the discs been physically checked?
I could only suggest that there might be hub damage, or that the refurbished caliper is faulty in some way.
Old Aug 30, 2010 | 09:58 AM
Big-Dan's Avatar
Big-Dan
I had the callers professionallly rebuilt by bigg red in worcester, brakes worked fine before bar the drivers side caliber seizing up if left sitting for a while. Pads, disks and pipes are all the same items that were in use before calipers were sent for refurb, when the car is jacked up neither of the front wheels spin freely, they are both very resistant.
Old Aug 30, 2010 | 11:10 AM
left hooker
i say rubber flex hoses crushed not letting the brake fluid back to the master cylinder intern holding your brakes on
ohh how free are your pads in the carier the have to move freely
Old Aug 30, 2010 | 02:46 PM
dojj's Avatar
dojj
Resident Wrestling Legend
remove the vacuum pipe from the servo and try them them out on the road
just be prepared to not be going fast and needing a BIG push on the brake pedal to stop
but it should eliminate a broken one way valve
you can then start checking for pipes and stuff and getting dirty that way
Old Aug 30, 2010 | 03:10 PM
mk2 cossie's Avatar
mk2 cossie
30kg is not a good enough reason to fail on the brake roller tester
how easily does the wheel turn by hand?
is it a front wheel, and have you got any kind of limited slip diff fitted? if so, it shouldnt even be near the roller brake tester
Old Aug 30, 2010 | 06:39 PM
I thought any binding was a fail ?
Old Aug 30, 2010 | 06:45 PM
Silver'Scort's Avatar
Silver'Scort
I did one at work the other week, and me dads a couple of weekends ago, where the brake hose had collapsed on the inside, and holding pressure in the calliper. Looked fine, didn't flex/bulge/distort and the pedal felt fine, obviuosly 'coz the fluid could force its way through under hydraulic pressure, just couldn't return.
Old Aug 30, 2010 | 07:10 PM
mk2 cossie's Avatar
mk2 cossie
theres an advise for slighly binding, and from my experience 30kg isnt binding enough for a fail. if the wheel cant be turned when in the air, then id be concerned about it. but if theres a LSD fitted then the MOT states that the vehicle should NOT be tested in the brake rollers anyway
as mentioned above, the flexi hoses can deteriorate internally and act as a one way valve
Old Aug 30, 2010 | 09:18 PM
Big-Dan's Avatar
Big-Dan
The wheels can't be turned freely when in the air, you really have to force them, both sides.
One thing I forgot to mention is that when bleeding the rear calipers hardly any fluid at all came out at all, could that be a sign of a collapsed hose?
Is there anyway I can diagnose whether or not a hose is at fault other than taking the current ones off?
I'll try and find out abit more info on the gearbox, pretty sure that it's a CTS stage 1 box with no diff but will find out to be sure.
Big-Dan.
Old Sep 2, 2010 | 01:03 PM
Big-Dan's Avatar
Big-Dan
Okay, a friend of mine has just asked me if the brake pads are the right way round.
He's just told me that there should be a left pad and a right pad for each disc and that the fibres of the pad are made so that they won't work in the opposite sides.
Is he winding me up or is this a genuine shout?
Big-Dan.
Old Sep 2, 2010 | 01:23 PM
Neil@FastFord's Avatar
Neil@FastFord
Big-Dan.
It does, CTS Stage 1 rebuild with standard LSD
Old Sep 2, 2010 | 01:25 PM
Big-Dan's Avatar
Big-Dan
Cheers mate
Big-Dan.
Old Sep 2, 2010 | 06:07 PM
bouncy's Avatar
bouncy
Just slacken each bleed nipple on each caliper in turn and se if they free-off. If they do its a pressure problem and not your calipers.
To check if its brake hoses, roller brake test them and see if they decrease at a good rate and arnt lazy!!!
Quite rare both hoses go at the same time though!
Old Sep 3, 2010 | 12:06 PM
mk2 cossie's Avatar
mk2 cossie
IF it has a lsd fitted IT SHOULDNT BE ROLLER BRAKE TESTED
Old Sep 3, 2010 | 01:43 PM
bouncy's Avatar
bouncy
You are correct, but I dont know if its has, this was just a general assumption as I thought it had all ready been RBT, also good advise for others if they dont have an LSD!!!
Why cant you test for hoses anyway on a RBT, surely as long as you set both rollers turning and DONT lock the wheels, it shouldnt be a problem!!
Surely, using only say 100kg of force, wont lock the brakes up and will be enough to detect a restricted hose
Just an idea!!!
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
