foa secs
cossiedave, Thanks for saying that Dave
It was nice mapping a car with decent injectors and turbo for a change !!!
For those who are interested.........
I should add, this was the new EEC4 plug and play version of the S8.
Only electrical changes to the car are 5 bar map sensor, injectors and MAF
sensor removed.
This includes a new version of software of the S8 that has an AUTO TUNING closed
loop fuelling feature from a wide band sensor. (Bosch 5 wire LSU sensor)
sensor removed.
sensor removed.
sensor removed.
Sounds pukka!
I guess you insert AFR targets in a fuel table and the Wideband just dials in the correct injector duration to achieve it when it reaches that load/speed site and then saves it to the map?
Should make home tuning very easy!
Of course you have got to know what AFR targets you want in the first place so I shouldn't imagine Stu or Karl will loose any business, just make it easier for those that will go DIY anyway.
When will this new version of software be on general relese?
sensor removed.
sensor removed.
very cool mate,,, im sure the people who change over eec4 esccos too large turbo spec will be out of work soon
cool that you got the autotune working
PassionBMW.com Member
No, am at my house in cardiff playing with my new anodising setup
Cars fine, got the day off on tuesday so I will finish off the back brakes (reconning the drums, new wheel cylinders etc, and fitting braided lines).....so gotta do that tuesday, get a lambda boss put in downpipe and then get her mapped
88_WRC_Replica
22-07-2004 03:03 AM
