vag 1.8t tuning
Old 15-08-2010 | 07:09 PM
rs-tuner's Avatar
rs-tuner
Talking vag 1.8t tuning
i am currently building a seat leon track car heres the link
https://passionford.com/forum/restor...with-pics.html
now im after some more power and as there are alot of knowledgeable people on here i thought i woiuld ask peoples opinions.
i have allready fitted coilovers/anti roll bars/wheels+tyres/and seats and harnesses.
the car is totally standard engine wise and i have about 4-5k to spend to get more power. i can do all the mechanical work myself.
Old 15-08-2010 | 09:06 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
What sort of power are you are you looking for and are you wanting to keep the original management?
Old 15-08-2010 | 09:09 PM
turbotoaster's Avatar
turbotoaster
front mount intercooler
lsd
bigger injectors
remap
turbo off an audi tt if you want less than 300bhp
if you want more then big turbo, gt2871 should be nice for 350bhp, if you want more then go bigger
Old 15-08-2010 | 09:21 PM
mobb-black's Avatar
mobb-black
filter/exhaust/remap at REVOTEKNIK. You'll be pushing 270bhp at that. Wanting more then move on to one of the tuning packages at Awesome GTi. Get a decent clutch.
Awesome GTi and the like have various low compression big turbo packages for around 4-5k that will push you to 350bhp +. The cupra already runs similar clobber to TT-225, so you would be best looking to the aftermarket for tuning options rather than other VAG models.
Dangerous Dave
Old 15-08-2010 | 09:36 PM
rs-tuner's Avatar
rs-tuner
not sure what i want really i remember you telling me the standard internals are crap
but other people say they take over 300bhp
im after something that is reliable and i can add more to as time goes on and more funds allow.
the engines done 124k so may be to tired for really big power ?
but i have to get the parts from somewhere and i know you have lots of experience with them.
Old 15-08-2010 | 09:48 PM
rs-tuner's Avatar
rs-tuner
lsd
bigger injectors
remap
the gt2871 kit is over 4k alone then i would need a front mount/ exhaust/filter and fuel system as well.
plus i dont know wether to trust the standard internals.
Old 15-08-2010 | 09:52 PM
Mint FRST's Avatar
Mint FRST
The Cupra R does but this is a Cupra so is K03s equipped and not K04 (Turbo that is).
The difference between then is around 60 more Bhp with a remap...
Old 15-08-2010 | 09:53 PM
Martin-Hadland
Fit rods as a minimum, they WILL fail! I'd be interested in taking on your project but I'm away until the end of the month.
Old 15-08-2010 | 09:56 PM
rs-tuner's Avatar
rs-tuner
No worries as I'm going to ze ring in it at the beginning of next month so it will be after then anyway
Old 15-08-2010 | 09:57 PM
vroomtshh's Avatar
vroomtshh
For track use an LSD will be way more useful than more power just yet
Old 15-08-2010 | 10:01 PM
Martin-Hadland
Cool, call me if interested.
Old 15-08-2010 | 10:05 PM
rs-tuner's Avatar
rs-tuner
Will do
Old 15-08-2010 | 10:13 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
Standard internals will take 300bhp but above this look at having the bottom end strengthened.
I'd go k03s hybrid injectors sports cat (if staying road legal) if not de-cat and free flow exh.
CAI front mount and re-map. Be knocking on the door of 300bhp with that lot. But I'd also look at dumping the dual mass flywheel and go for the G60 flywheel with uprated VR6 clutch.
Old 15-08-2010 | 10:24 PM
Martin-Hadland
I've had a rod poke through a block at 260hp on a very low mileage engine so do you think spending £350 on rods is worthwhile?
Old 15-08-2010 | 10:34 PM
Dicko&Vacant's Avatar
Dicko&Vacant
id go ihi rather then gt28 imo having had both conversions the ihi is far better. my ihi'd ibiza was running aprox 360hp on a totally standard engine and it got its arse kicked everytime it was used.
Old 15-08-2010 | 10:51 PM
rs-tuner's Avatar
rs-tuner
Never heard of ihi ?
360 bhp on standard internals is mental.
I would be scared to use it
Old 15-08-2010 | 10:54 PM
Martin-Hadland
[quote=rs-tuner;5047166]Never heard of ihi ?
quote]
IHI is a turbo manufacturer!
Old 15-08-2010 | 11:00 PM
rs-tuner's Avatar
rs-tuner
[QUOTE=Martin-Reyland;5047172]
quote]
What's the difference between these and the garrett gt ?
Old 15-08-2010 | 11:10 PM
Martin-Hadland
[quote=rs-tuner;5047186]
Different companies, I have IHI but will end up going Garrett GT3071. If you can decide what you really want then its easy to spec a turbo but then you eventually want more
Old 15-08-2010 | 11:13 PM
cozzy940's Avatar
cozzy940
check out jabbasport there the daddies with vag engines
Old 16-08-2010 | 12:14 AM
Dlatch!'s Avatar
Dlatch!
if your concerned about the mileage then a rebuild with stronger parts plus lower comp seems the only sensible way to go then power mods will be just bolt on.
the LSD and uprated clutch is a must have too. what they like for oil surge?
spend the cash making it as strong as possible then wind up the boost
Old 16-08-2010 | 07:27 AM
Johnny Knoxville's Avatar
Johnny Knoxville
My friend has a S3 and he's doing a bit of tuning to that. So for he has rebuilt the engine as a 2.1 using a TDI Mk4 Golf crank, ported small port head, steel rods, JE Pistons, Total seal rings, one piece valves, 370cc inj, hybrid turbo from CR Turbos with RS6 exhaust wheel and billet inlet, steel single mass flywheel, 3in down pipe so should about 320bhp.
The valves are also a weak part of the engine, the fuel pumps can also fail when pushed hard
Old 16-08-2010 | 06:27 PM
rs-tuner's Avatar
rs-tuner
[quote=Martin-Reyland;5047205]
what parts would you recommend for 5k then martin?
if it was yours what would you do ?
Old 17-08-2010 | 11:47 AM
Dicko&Vacant
my old leon cupra r was gt28rs forged pistons,rods etc had allsorts done to it cost the lad a fortune had stg3 revo only made 330hp.
the ibiza was standard engine ihi vf34 turbo big injectors,dta pro ecu mapped by a place round our way called auto mark and made 359hp.
heres a couple of pics of both cars lol
Old 22-08-2010 | 07:03 PM
rs-tuner's Avatar
rs-tuner
That Ibiza must have bein mental
Old 22-08-2010 | 07:45 PM
gjh's Avatar
gjh
[quote=Martin-Reyland;5047172]
quote]
Didn't they do the turbo's on subaru rally cars?
Old 22-08-2010 | 08:22 PM
nick8saff's Avatar
nick8saff
Did you buy or sell your ibiza from walsall area buy any chance
Old 22-08-2010 | 08:51 PM
Bobby Singh's Avatar
Bobby Singh
My mate has a Jabba IHI LCR BAM engine (stock internals) - but after 12k miles the turbo failed and had to get another fitted £900 plus.
But either way its a fast car with at least a proper 320hp
Old 22-08-2010 | 11:57 PM
Alps Pacino's Avatar
Alps Pacino
no it got bought from just outside redcar and sold to me. It been sat in me unit in bits ever since lol
Old 23-08-2010 | 12:18 AM
RS Grant's Avatar
RS Grant
Made in Scotland
IHI supply the Turbos used in almost all/all the STi versions of the Impreza road cars mate. The IHI VF34 is from a 2002 UK STi, its actually what I've got fitted to my 2000 UK Turbo and it (IMO) is a fantastic turbo, makes 338bhp on my car using c1.5bar peak boost.
Whats up with it? ...or you pulled it apart to tinker with it further?
Cheers,
Grant
Old 23-08-2010 | 12:24 AM
Alps Pacino
pulled it apart cause the exhaust was blowing at the back of the engine so stripped it all down and found the manitold was cracked. I then bought a few bits for it and had a proper cage welded in, so the list of jobs is
put manifold and turbo back on
put seats and harnesses in
put pro alloy tank and fuel system in
put perspex windows in
and a few other little tidy up jobs
I need to get me finger out but i've managed 300 days offshore the past year so havent really had the time tbh lol
Old 23-08-2010 | 08:55 AM
rs-tuner's Avatar
rs-tuner
Stop working and get it sorted !
Old 23-08-2010 | 11:11 AM
Alps Pacino
i cant cause the work keeps rolling in and i like the money lol
Old 23-08-2010 | 11:14 AM
Mike C's Avatar
Mike C
The Special One
Get it back up and running! I'd never taken any notice of these at all until I saw that one, and I REALLY like it!
Old 23-08-2010 | 11:42 AM
rs-tuner's Avatar
rs-tuner
You can get hold of them cheep aswell
Old 23-08-2010 | 12:27 PM
Alps Pacino
It will be back next year better than ever honnestly lol
Old 23-08-2010 | 12:53 PM
left hooker's Avatar
left hooker
www.rk-engineering.co.uk
Oranoco
41
11-02-2016 02:28 PM
A.t.p
29-09-2015 06:04 PM
SMILER258
28-09-2015 10:04 AM
`spotty
26-09-2015 12:41 AM
bassboy
10-09-2015 09:54 PM
