cossie wrc engine without restrictor, how much bhp?
As topic.. if you remove the restrictor on a later spec wrc engine and remap it, how much horsepower are you likely to see?
My understanding off the basic premise is that the turbo is spec'd so as to max out the restrictor very early on - effectively they have 300bhp from 4000-7000 rpm. So removing would probably result in massive surge problems...
Done this a couple of times..
If you just remove the restictor on the turbo it will do circa 340-350 hp
cheers danny
B1mbo
thats about right danny
we done a grp a engine for a guy who wanted the car for sprints too,
the t34 non restrictor made exactly 400bhp
but you have to remember, a wrc engine being at 10. something :1 cr any looked at every 1000 stage miles may not be so good long term as a properly specced road engine
the engine in question has an ihi turbo and 10.4:1 comp.
And if it makes 400bhp compared to the 300-330bhp with a restrictor, it is a significant gain if you ask me.
So anyone had any experience with a non restrictor ihi turbo?
cheers danny
Mark,
I'd sell the IHI and buy a turbo more suited to your application, the IHI has a very low trim on the compressor wheel and dependant on which back housing is fitted could be restrictive above the design parameters. The IHI has a fairly small envelope in which maximum efficency is exhibited and as such trying to (get more out of it) would be pointless in my opinion...
The whole WRC engine package is a little unique and to be fair you could acheive 400 BHP cheaper and probably more reliably by going a different route..
By removing the restrictor you are going to see a decrease in air speed and as such ports, cams, exhaust etc would potentially need re-working...
The wrc engine is mapped to achieve maximum efficency against choke point (PRP) post restrictor pressure and as such eliminating the choke point (restrictor), still run a high C/R not re-work the motor and not run race fuel would dramatically reduce the life expectancy of the engine...
also, future plans involves replacing turbo and running e85, any thoughts about that?
I recon the high cr is an advantage when running e85, and as there is 8 injectors, changing them to support the increased fuel needed is no problem.
Guess the head would need rework, but the cams should be good to achieve low end torque.
