Attn all fishing people help needed
Ive been fishing a few times with friends and fed up of being the one watching and having a go every now and then so ive just splashed out on a 13ft shimano catana rod and need some advise re reels as i really have no idea and wondered what you guys would recomend
J
J
burnzy
a bait runner reel anything from shimano or daiwa will be good really, browning do some nice stuff too but i'd stick to the first 2 for a good bait runner reel, shimano will be of better quality but you'll pay for it depends on what you wanna spend?
good luck with your fishing though i really enjoy it as something relaxing to do when i can't be arsed to do nothing else but sit down and chill out
shimano bait runners are all good reels some can be pricy but a good reel allways is start off with a chepish one or sec hand then as you progress ugrade gear i always say its how and where you fish not what you fish with
Would something like this be good ?
http://cgi.ebay.co.uk/SHIMANO-BAITRU...ht_1460wt_1139
dont want to get too into it lol ( famous last words )
burnzy
Yea i think it was mainly carp in there a few other names but i dont remember what they are
basically looking for a rod reel sleeve to come in at approx Ł150
so far
Shimano 13ft rodd Ł80
Poss reel above Ł50 approx
nice sleeve Ł20
might get a set of floats and all the other bits i can use theres lol
so far
nice sleeve Ł20
burnzy
I dont mind paying good money for a good product as also if i ever wanted to sell up want something that will sell rather than just bin or boot sale
burnzy
and you wan't the bait runner as when your carp fishing you'll have the rod on bite alarms and it'll let the fish pull the line off as it shoots off without pulling your new rod into the water
that would be better as it has 2 ball bearing in it would make it smother to use has all the functions like the other one only don't have the twin handle but that makes next to no difference really.
will be still fine to catch all other fish on too
funny you say that some guy cast his line and it got a bite straight away and off went his rod into the water it took aged for them to get it back trying to cast a line to grab it
was funny
burnzy
are you sure its a carp rod and not a match rod
if it is a match rod you dont really want a baitrunner on it
see if you can find a link to the exact rod you have and you will get better advice and are you the same B16JUS thats on tp
This is the rod
http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_817wt_1139
yea on TP too
whats the difference between a carp rod and match ?
yea on TP too
burnzy
i'v been close in the past when baitrunners where relativley not heard of daiwa where the first to bring them out iirc, and had to catch the rod as it came off the rests
not a funny sight if it's your rod flying through the water proper hysterical if your watching someone else running round after there rod thought
burnzy
This is the rod
yea on TP too
yea on TP too
you could still use a smaller bait runner but like said if it's on your coarse rod it's not deffo needed, i still use one as you set the drag and it 's just piece of mind if you aren't 100% engrosed on your rod and something does take it it won't go into the lake
and the difference is a carp rod is alot stronger and you usually only detect bites through a bite alarm your match/coarse rod is lighter allowing to keep the line taught on smaller fish by using the bend in the rod and you can use the tip of the rod as an indicator by resting the rod at a near 90 deg angle to where your bait is and putting tension on the line till there is a slight bend in the rod thus being able to show whether the fish pulls on you bait towards you or away from you, or you can use a float with the match rod aswell
a match rod would usually use lighter line than a carp rod 2lb - 8lb line with a match type reel
a carp rod you would use 8lb - 15lb line as the eyes will be much bigger etc
i would pop into your local tackle shop and tell them where your fishing and what for and the rod you have and they will show you some reels
i have 5 shimano baitrunners but never use them on a match rod
as above you could use one of the smaller models of baitrunner and you could then use it on a ledgering rod once you progress on to that
where in essex are you as there are loads of good tackle shops around
burnzy
it is all down to preference i do agree that on a match rod it's not really needed just i find it a saftey measure if your not 100% focused as a carp or other large fish decides to run off with your bait
Im romford
That second hand one went for 37 so left it
for a starter would a baitrunner reel make that much odds on a match rod ? is it worth waiting for another used one or shall i just get the new one below as its the same seller so i can get them to post it with the rod
RS2000 4x4
i know its not new but i have a reel like this one, it would be about perfect for the rod you have, also has 2 spools so you have have two different breaking strains of line on depending on what fishing your doing or fish your after
http://cgi.ebay.co.uk/Shimano-Sahara...item35ab5d3280
burnzy
it's a toughy now as i said before i didn't realise shimano made two different rod's with the same name ![Wall](https://passionford.com/forum/images/smilies/wall.gif)
as we have both said if you think your going to stick with the fishing then yes it'll be worth it as you can use it just like a normal reel just you have the bait runner on it if and when needed, i'll have a look at some normal shimano reels and see what i can post up but that first one you put up is still a good buy if you stick with your fishing it'll stay in your tackle box as it's a worthy reel
brand new Ł55
http://cgi.ebay.co.uk/SHIMANO-SAHARA...#ht_1939wt_913
so at the moment its between
shimano aero 5000 xe ( baitrunner )
shimano sahara 3000fd ( 3 bearings )
brand new Ł55
i wish my oldest lad was here as he works in a tackle shop but guess where the little shit is (fishing) lol
i really would go into a local shop as a lot of these reels come in various sizes
have a look here for example http://www.bowlersangling.co.uk/Shor...4&sub=SHIMCREE
Have i purchased the wrong rod really ?
would i be better of with something like this ? as i can always ask them to change the order then i can go for the baitrunner reel ?
http://cgi.ebay.co.uk/NEW-SHIMANO-AL...f#ht_533wt_913
burnzy
the only trouble is that sahara reel is more designed for spinning than anything else, here is a catana reel so would suit your rod as they come from the same line of products comes in cheaper at Ł26 but only has 2 Ball Bearing and a Roller Bearing will still be a good reel though.
the tough bit is knowing whether you'd keep the fishing going as spending Ł26 on a reel is a bit easier than Ł55, you'd be fine on that catana reel but obviously you just don't have the bait runner for further progression of your fishing
on another note you could also look at it as if you do progress you could get yourself a carp rod if your fishing on lakes mostly and then buy the bait runner to go with the carp rod so you'd then have 2 rods to use if you really wanted with reels to match the rods
http://cgi.ebay.co.uk/Shimano-Catana...#ht_1436wt_828
so far
nice sleeve Ł20
so far
nice sleeve Ł20
were you float fishing when you went with your mates before
if yes and thats what you want to try then the match rod is the correct rod
if they were fishing with lead weights only as in ledgering then you would need a type of specimen rod
if carp fishing then a carp rod and baitrunner style of reel is what you need
i was also going on this mate
burnzy
you might not of bought the wrong rod but as we don't know the lake you fish with your mates and what type of fishing you get upto then this is why it's eventually been put to just go into the local tackle shop and get your advice from there, sorry mate i tried but i also would feel bad if you did end up with the wrong gear as i think you need some more info on what where and how your fishing to make the right choice here
burnzy
also that catana reel i posted up a few posts before would be fine for float fishing you won't need a bait runner to float fish with as you'll always have the rod in you hand
Thanks for all your help guys, will be funny seeing the look on my mates face when i meet them next esp turning up with a rod lol
just need to sort a licence out next
honestly mate please pop into your local tackle shop and try a couple out to see what feels right in YOUR hands
float reels will usually have two spools one shallow for light line say 2lb breaking strain and a deeper one that would take say 6lb line if you fancied a bit of ledgering while you had the traditional afternoon kip
enjoy it and you have a hobby for life
burnzy
CrOwSoN15
18
22-08-2015 10:24 PM
muz
16-08-2015 12:57 PM
