Sending mms on iphone 3gs ?
Firstly, go to settings > Messages and make sure MSS Messaging is set to on;
Then you probably need to do a reboot of the phone before doing the next bit.
After reboot, go to Settings > General > Network > Cellular Data Network and make sure the APN is filled in for MMS;
Obviously, those APN settings are for T-Mobile so don't copy them. Try the following;
http://shop.o2.co.uk/update/settings.html
Mines fine on o2,as above.get a mates and check all your settings are the same,the missus had a prob with hers the other night and we compared the settings and one thing was turned off on hers,no idea why!!!!
u can still send mms on 3g just make sure it is not in airplane mode then take a pic view it then at the bottom you should have a box with a arrow coming out as in send mms should be in there..
have u tried going into the bit where u write a tex message and next to where you write on the left there is a little camera push that go to choose existing select what photo you want see if that works
I would suggest you restore the iPhone and re-install IS4.01 . I had to do this on my 3G last week as the first upgrade didn't install properly. It sounds like a similar problem and some features have not been installed.
ive asked mate and they said it could be a problem with your settings and you will have to do a restore via itunes but make sure you sync everything first
