HOW MUCH DOES A COSSIE ENGINE WEIGH!?
The pinto on which the cosworth was built on weighs 130kg.
At a guess the engine may weight less due to the fact the head is alloy - therefore 120 - 125 kg i recon.
Thanks
Darren
Thanks
Darren
The orginal heads were very heavy, the cosworth head will weight very similar or slightly more than the origninal.
15 kg more is far to much, that is my opion anyway, i have had more experience with the pinto than cossie though.
Darren
Darren
The alloy sump weighs twice as much as the pressed steel pinto item???
Crank is heavier, head is heavier, exhaust manifold heavier than pinto, but pintos don't really weigh in at 130 do they? I had them down as closer to 110, as I know I can't lift 130!!!
09-10-2015 07:38 PM
rog
04-09-2015 12:10 PM
lockie
31-07-2015 10:03 PM
