Fitting a GT35?
Fitting a GT35?
How much work is needed to install this type of turbo?
Are there kits avalible to modify your manifold for an external wastegate?
What about v-band connections? is there kits avalible for the downpipe?
Really would like to see one of these in my engine bay and have had a cracking chance for one. Been told its a bit overkill for my 400bhp build but that could change also.
Bit of guidence would be great chaps.
500bhp Cosworth in making
i run a gt35 you just need the adapter pipe under the turbo for oil return from AET turbos. if your fitting it to a 2wd you will need a reyland manifold spacer so housing can clear the head. i used vband as its a lot easier to remove. i also got this from AET turbos.
GT35 you only want to use it if your going over 550bhp min
track.focus'd
12-08-2015 05:53 PM
