Twin caliper brake set up..........?????????
Location: *PF TERRORISTS CARTEL* Bin flocking Youngens :cry:
could this work??
Instead of having one fook off caliper, could you have 2 mounted oposite each other or something?? sure someone like brom could fabricate the mounts no worries.
I cant see why not.....
very helpful
thinking it could be an alternative to having to buy mo's
but still upgrading brakes
interesting
how much difference does having fook off discs make then??
say you had 300mm discs with a twin cossie 4 pot set up for example. would the discs not cope
is it me or has that maybach got 21's on
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Bigger disc = bigger pads, which can aid brake cooling.
You may struggle shifting enough brake fluid, as the master cylinder would have to fill 6 calipers instead of the normal 4
So you may have to change the master cylinder too
Also some car makers mount the brake caliper at the front of the disc and some at the rear, why is that, does it impove breaking?
Which is best?
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
Which is best?
I've got a 330mm 4pot set up on the rear, as well as an RS200 handbrake caliper............just to be different as i can't be doing with a hydraulic handbrake
Caraholic
Dom,
You really are a spaz
. Firstly, Cossie 4-pots wouldn't fit behind your wheels, so you would have to buy a set of MOs anyway
Secondly, good luck in getting it to work adequately
Thirdly, the extra unsprung weight of two cast-iron Cossie 4-pots per side would be detrimental to the handling
Fourthly, just do it fucking properly you gimp
. I bet it would be cheaper
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
2 cossie 4x4 calipers it is then
Passionford was running slow and I was bored so I thought I'd post this up rofl
![](https://passionford.com/forum/images/smilies/smile012.gif)
abi titmus, dirty slut
you didnt stick around long at the meet. was just walking over with a few people to look at your car........as you foooked off down the road
track.focus'd
12-08-2015 05:53 PM
