YB 2wd Cams
Cosworth 7
YB 2wd Cams
General advice if possible.
What cams do people recommend to run 450/500 bhp.
Rest of the engine and head would be sorted, ported head, double springs, inlet, turbo etc.
I am not looking for cams that "trip over" themselves either, no point in blowing the boost out the exhaust before it’s done the job.
Thanks
James
Thanks
James
TT T38 Power
I have just had a AB07 (inlet) cam fitted to mine and gained 35bhp with the same boost. Was 399.8bhp now 434.5bhp.
Drives just as nice as the standard cam and ticks over perfect.
Was Rolling Roaded on the same rollers before and after. Dyno Dynamics Rollers.
Steve
Steve
Depends on cr size of ports and turbo your running???
These days i like very close to std cr valve cut outs 25mm ports std ex cam 10 mm lift 280 duration inlet cam siemens injectors and a gt3071 turbo..
awesome set up for fast road and track car and will achieve your goals..
cheers danny
cheers danny
Its all about the lift and duration on the inlet and no need for a bigger exhaust untill after 500 hp...
cheers danny
At worst take the ex cam out and put a std one back,dti inlet cam then play with verniers untill your happy...
What cr you running???
cheers danny
All it means is the lower the cr the longer you wait for positive boost but a good mapper can get around that to a certain degree...
cheers danny
Mc5506
05-10-2015 09:57 PM
