General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I have a stg3 YB and it won't produce more than 9PSI. when I switch the ignition on the amal valve doesn't click on and off, what are my options, a new Amal, a MSD air to air injector or is the an aftermarket boost controller recommended?
I had a problem with my amal valve fitted a new one and couldn't get more than 10 psi , in the end found out it was the jet in the air filter return on the Amal valve, after I removed that it was fine.
I've fitted a new one but that doesn't click either, should it? Also which pins are they connected to on the ECU please? I've fitted MSD closed loop and wasted spark since it's last use so I may have poor wiring, worth a free check.
