bodyshop con's and pro's,bare metal
paint stripper is prob the quickest way... all are as good as each other, its the prep that makes the difference between a good or lovely paint job... if its an old car you can acid dip it , but that means stripping eveything off theshell and obviously meens a lot more work...
cosworth gimp
personally i would steer clear of any paint stripper as does cause problems with fresh paint sometimes !!
ELBOW GREASE is your friend
![](https://passionford.com/forum/images/smilies/roi.gif)
take it back down with that then go over it with 120 grit etch and then a good quality high build primer spend more on this don't get cheap stuff
for all the bits you carn't get with da use a wire wheel on grinder not a five minute job i would do one panel at time then etch it as you go
cheers dingle
