Mk6 rs2000
Mk6 rs2000
Got a thick black pipe hanging near radiator not connected and i cant see where its connected to its not wet im bloody puzzled ..Cars not running hot and running well just about to consult haynes manual ..any one got any ideas
My Cossie Ate My Money
Lucifer II - 666
Lucifer II - 666
Na leave it unless you going to start modifying the engine on your car?
Lucifer II - 666
no shouldnt be, as long as it is the black tube that goes up to a black box hucked onto side of your manifold.
if it were anything else I guess it wouldnt be runnign as wel as you say it is anyway.
Lucifer II - 666
Only of your intending to modify the engine in other ways such as cams, inlet, exhaust etc
if not just leave it.
Lucifer II - 666
Was not correcting you Kev, as I know you know whats what, and like me you must get sick and tired of correcting everyone!
It was for everyone else's attention.
EGR = exhaust gas recirculation, which I believe is for emissions/enviro reasons and does what it says, re-itroduces exhaust gases back into the inlet system.
APS = air pulse system and is used to bring the CAT up to heat quickly, as they only work once hot enough and again is for emission reasons, and it does this by bleeding fresh air into the exhaust manifold, which allows any un-burnt fuel present to combust and generate more heat in the exhaust and heat the CAT quicker. This usually only runs from a cold start up.
Lucifer II - 666
Fordmad!
15
27-09-2015 06:24 PM
mk1focus
Ford Fiesta
24-09-2015 06:19 PM
Vacuman
22-09-2015 12:09 PM
