Lets see your Zetec Turbo engine bays!!!
Mines not finished but got this far at the moment
![Name: DSCN3812.jpg
Size: 77.6 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170246d1502131792-lets-see-your-zetec-turbo-engine-bays-dscn3812.jpg)
![Name: DSCN3811.jpg
Size: 77.6 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170247d1502131792-lets-see-your-zetec-turbo-engine-bays-dscn3811.jpg)
![Name: DSCN3799.jpg
Size: 81.0 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170248d1502131792-lets-see-your-zetec-turbo-engine-bays-dscn3799.jpg)
![Name: DSCN3798.jpg
Size: 83.9 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170249d1502131792-lets-see-your-zetec-turbo-engine-bays-dscn3798.jpg)
![Name: DSCN3803.jpg
Size: 67.9 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170250d1502131792-lets-see-your-zetec-turbo-engine-bays-dscn3803.jpg)
![Name: DSCN3808.jpg
Size: 78.5 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170251d1502131792-lets-see-your-zetec-turbo-engine-bays-dscn3808.jpg)
![Name: DSCN3809.jpg
Size: 77.9 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170252d1502131792-lets-see-your-zetec-turbo-engine-bays-dscn3809.jpg)
The Spec so far is
ZETEC TURBO ENGINE
THE ENGINE HAS BEEN BORED FROM A 2.0 TO A 2.1 LITRE CAPACITY (REBORE WAS DONE BY IAN HOWALL)
ARP BOLTS THROUGHOUT
WRC STEEL RODS
ARIAS PISTONS
IAN HOWALL SPECIAL CAMS
DOUBLE VALVE SPRINGS
STEEL MULTI LAYER HEAD GASKET
STAGE 2 BRAND NEW T34 TURBO WITH MODIFIED EXHAUST HOUSING
BILLET FUEL RAIL WITH WEBBER INJECTORS
RS1800 INLET MANIFOLD AND THROTTLE BODY
3 BAR MAP SENSOR
COSSIE FUEL PRESSURE REGULATOR
Brian
The Spec so far is
ZETEC TURBO ENGINE
WRC STEEL RODS
ARIAS PISTONS
3 BAR MAP SENSOR
Brian
Baby Cheesus
SDC10884.jpg?t=1276980057
brief spec lol:
2.0l bored to 2005cc, wiseco low comp pistons, carrillo rods, heavy duty bearings, custom baffled sump, polished std crank, satge 3 big valve head, piper BD10 grind cams, piper verniers, titan motorsport rollerbarrel throttles, siemens 650cc injectors, custom inlet plenum (made by 34chassis), modified XS power 200sx manfild, XS power T4 spec turbo, XS power external wastegate, custom exhaust made by hayward and scott, pro alloy rs500 intercooler and rad and custom pipework, xs power FPR, DTA S40 ecu.
power, about 100bhp as its not mapped yet lol
brief spec lol:
heres a few of mine
my old mk3 fiesta zetec turbo my first ever car , i really loved this car and soon to make a come back with a new owner which make me really happy
![Name: Image0068.jpg
Size: 73.1 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170262d1502131792-lets-see-your-zetec-turbo-engine-bays-image0068.jpg)
![Name: Image0069.jpg
Size: 81.6 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170263d1502131792-lets-see-your-zetec-turbo-engine-bays-image0069.jpg)
that was 2.1 litres
t34
arias low comp pistons 7:45:1
h beam rods with arp bolts
standard ford mulity layer head gasket
rs1800 inlet with holley injectors
standard head with uprated valve springs
esrt exhaust manifold
uprated fuel pressure reg
pro alloy large front mounted intercooler
large escort turbo stainless cone filter
bailey motorsport oil breather
fiesta turbo ofab management with ahmed bayjoo live map , 15 psi low boost , 21 psi high boost , running a solid 300bhp
a very quick car , engine reliable , gearbox not lol
my 522bhp engine sadly never fitted in a car as things have changed so much
![Name: paulpics030.jpg
Size: 115.0 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170264d1502131792-lets-see-your-zetec-turbo-engine-bays-paulpics030.jpg)
the very same bottom end as above ie rods , pistons
but with big valve cylinder head
double valve springs
raceline fully baffled sump
t61 turbonetics turbo
tial 44mm wastegate
custom built exhaust manifold by myself
piper venier pulleys
area six custom inlet manifold with x 4 625cc siemans injectors
cosworth duratec 67mm throttle body
secert spec cams
pectel t2 with custom wiring harness by myself
aeromotive fuel pressure reg
engine dynod by harvey gibbs and ahmed bayjoo at scs
engine made 522bhp and 395ftlbs @ 30 psi
now as happy as i was things have changed again because of going 4x4 and many other little things have changed in trying to build the most powerful and reliable zetec turbo in the uk
this is now the engine nearing its final build and i mean final build lol
things that have changed and have been added
jenvey inlet manifold modified to accept x4 625 siemanns injectors and x4 bosch 450cc injectors also with evo hi flow 70mm diffuser
new secert spec cams
billet thermostat housing (got to order)
custom hand built twin scholl exhaust manifold (still got to finish)
x 4 exhaust temperture sensors , 1 in each header
twin tial 44mm wastegates (1 to order)
pace dry sump system but with are dry sump pump (on order as we speak)
modified cam cover(being done as we speak)
alloy lightweight pulleys (got to order)
plug on coils (on order)
vacuum block (on order)
modify head studs to 11m or 12mm (will be done when the engine returns to ian)
some of this stuff has been added to aid a bhp increase and some for reliability
we are hoping to see a genuine 625/650bhp @ 35 psi max
it may change slightly from the pics as it is not finished yet
![Name: paulpics608.jpg
Size: 50.2 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170265d1502131792-lets-see-your-zetec-turbo-engine-bays-paulpics608.jpg)
![Name: paulpics610.jpg
Size: 44.0 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170266d1502131792-lets-see-your-zetec-turbo-engine-bays-paulpics610.jpg)
cheers paul
that was 2.1 litres
t34
tial 44mm wastegate
secert spec cams
cheers paul
no , its lived there once and didnt get along with the gearbox or clutch lol![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
its needs two wastegates on twin scroll 1 for each pair of headers , now i was thinking of not doing it but everyone should read about how it can save you upto 800rpm on spool up time with an identical turbo set up with the same boost . read it on the mlr forum , very good back to back testing and even they where surpised how much difference it made , so i thought i may aswell give it a bash as i will be making it myself.![Top](https://passionford.com/forum/images/smilies/smile011.gif)
cheers paul
cheers paul
B1mbo
heres a few of mine
![](http://i457.photobucket.com/albums/qq300/ZETABOOSTBOY522BHP/Image0068.jpg)
![](http://i457.photobucket.com/albums/qq300/ZETABOOSTBOY522BHP/Image0069.jpg)
that was 2.1 litres
t34
![](http://i457.photobucket.com/albums/qq300/ZETABOOSTBOY522BHP/paulpics030.jpg)
tial 44mm wastegate
secert spec cams
![](http://i457.photobucket.com/albums/qq300/ZETABOOSTBOY522BHP/paulpics608.jpg)
![](http://i457.photobucket.com/albums/qq300/ZETABOOSTBOY522BHP/paulpics610.jpg)
cheers paul
that was 2.1 litres
t34
tial 44mm wastegate
secert spec cams
cheers paul
look forward to this on the dyno mate
me too jimbo , but i must admit that its always abit unnerving seeing your engine rev to 7500 rpm , or maybe 8500/9000rpm this time with everything glowing red lol. as soon as the oil pump is sorted then things will move faster and maybe be ready before august, we will see.
i must remember more video batteries next time as i recorded all the non boost mapping and the fuckin thing ran out at 470 bhp which i must say was a shame .
can you tell me if pectel t2 is ok running plug on coils?
cheers paul
cheers paul
B1mbo
cheers paul![Top](https://passionford.com/forum/images/smilies/smile011.gif)
cheers paul
hmm not, im not sure about coil on plug with t2 thats a good one, i will find out for you though !
what sort of cams are you using in this, if thats not classified info lol
YES I KNOW I CANT SPELL
just look for the lad thats head and shoulders above anyone else lol , that would be great if you could find out jimbo , and as for cams there going to be ians secert spec but iam sure he will tell your old man before mapping as even i dont know yet as hes having a play and a think at the mo
cheers paul
Baby Cheesus
it runs but is on a basemap that was on the dta, for a 2.0l zetec ginetta race lol, and its overfueling like a coont. so it does drive.
i need a good weekend to finish off a few bits then it can be mot'd, so really very little to do, just no time to do it!
B1mbo
cheers paul
cheers paul
cool
![](https://passionford.com/forum/images/smilies/roi.gif)
cheers paul
i'll post you pics soon of the modified cam cover , ive got the blue one on my engine for £30 if you want that , ready to go , if not let us know when your bringing yours over.
cheers paul
maybe i will drag you along for the day , but we both maybe be dead by the time its ready for the dyno lol![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
cheers paul
hhmmm i love that blue cam cover
Heres my bay...
![Name: SemiComplete1.jpg
Size: 139.7 KB](https://passionford.com/forum/attachments/general-car-related-discussion/170275d1502131792-lets-see-your-zetec-turbo-engine-bays-semicomplete1.jpg)
Quick spec: -
2.1 Zetec instead of the crap duratec and ib5box
Getrag 6speed st170 box
GT30 with external gate and screemer pipe
Fully forged
area six inlet
Over the box exhaust mani
made 340 at about 18psi.
But now broke it and building a new one with a ported head etc etc aiming for 400bhp in a fiesta ST
Quick spec: -
Fully forged
area six inlet
Heres my bay...
![](http://i252.photobucket.com/albums/hh10/AlexStichbury/SemiComplete1.jpg)
Quick spec: -
Fully forged
area six inlet
Quick spec: -
Fully forged
area six inlet
alex !!!!!! hello and welcome matey , hadnt realised that you joined us , shame about the engine are you getting ian to do the bottom end? , nice looking engine bay , and another one of my manifolds , not that you can see it under all that wrap lol.
how long until its back on the road.
luca that bay is now perfect mate i dont think ive ever seen such a clean car
p.s some great engines and bays good work lads
cheers paul
i will now be spending another £850 on a billet oil pump from the states , specially designed for drag high boost cars . its took me ages to find info with some companies not even interested , but ive found a brilliant company that make all nascar pumps and systems and they are the finest quality.
let us know if your having any trouble or if you need any help
cheers paul
