MY FIESTA RS TURBO SPEC can anyone advise?
Needs Beer Tokens.....
Right chaps i have the bits ready and the car running but it wont be ready for rolling road before i have painted the whole car as im restoring it, can anyone tell me what the thought of this front mount IF they have used it?:
http://www.autospecialists.co.uk/Pol...oduct-866.html
and what they think i will get bhp wise outta the engine spec:
Fully lightened and balanced
uprated fuel pump
beige injectors
superchipped
standard t3 conversion
cone filter
Stainless scorpion exhaust
and the front mount intercooler in the link
Am hoping for 200bhp am i dreaming? cheers
uprated fuel pump
beige injectors
superchipped
cone filter
No reason why you shouldn't get 200bhp.
Is yours an OFAB or OFAC car?
Mine was OFAB, the better option of the standard gear, or it used to be unless things have changed.
The intercooler is fine for your spec. Mine used to do 225bhp consistant and had standard cooler (for a short while) and a very similar spec standard head and cam etc. I uprated the head and cam later, did nothing as the injectors were maxed out.
I presume you will be getting it chipped as i don't see that on your spec, you will need one or someone like MSD or Grove who can map it for you.
and again, thanks alot for that information
From memory my map sensor was on the bulkhead on the right hand side of the inlet. Ecu was in the passnger footwelll. But i'm trying to think back a good few years.
If you have a 195 chip you will be alright, if it's the 165, you won't. But pretty sure Collins have chips, MSD, Burtons even. It's not tricky to sort it and you have all the bits to get sensible power.
YES I KNOW I CANT SPELL
cosworth and ofab use diffrent map sensers. all tho they look the same the part numbers are different
JoeyBoyden
04-01-2024 02:36 PM
Matt Baxter
16-09-2015 08:30 PM
