Anchoring chains to a concrete floor. How ?????????????
Soon i am going to be laying a new concrete base for a garage and i would like to put some sort of eyelets into it for attatching chains/padlocks too. I would like something that lays flat into the floor when not in use so i dont trip over it but can be lifted up when i want to use it. The problem is i cant find anything suitable and cant even think what such a thing wuld be called ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Anyone got any ideas?
Cheers Gaz
Cheers Gaz
Carbon Crazy
look for ground anchors mate. loads of them out there.
http://www.yanchor.com/
http://www.elitesecuritysupplies.com/ground_anchors.htm
dont get anything just using bolts.
Right at the bottom, not cheap mind!
http://www.biketurner.co.uk/html/groundanchor.html
Or here?
Or here?
ive set a mtr of chain in the base to previous garage with just a couple of links showning.you would have needed a crane to take it out and would probably have took the base with it as i sank reinforcing mesh in it to....
When me mate did his garage floor, he had the same issue, so he used what I suggested, a old car suspension spring with a strong proper chain, chain "eye" was slid 1/2 way down spring, then buried about 2 feet(?) down, chain just lays flat on floor and doesn't get in the way, total cost zero as he had these bits anyway.
the towing eye off a car,just get some threaded end to put in the ground and you can then screw it in when needed ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
can put a few around the floor,plenty at the scrapyard
I,ve got 2 2" square box section 'Y' pieces concreted into my garage floor securing my bikes
Remember though the anchor is only as good as the chain fastened to it!
My mate had a shithot anchor in the floor but the shite chain took the theifs about 3secs to get through!
