welding 2wd diff up???
Old Jun 6, 2010 | 08:39 PM
Butch.'s Avatar
Butch.
Default welding 2wd diff up???
advice please been at pod today with my mates 2wd saph and just cant get traction cus 1 wheel is spinning all the time so he's thinking about getting it welded up firstly is easy to weld up and how do you do it? and will it brake like a normal diff will once welded... he only uses it at pod no on the road really...
thanks
Old Jun 6, 2010 | 08:45 PM
R4N SS's Avatar
R4N SS
if only 1 wheel is spinning your diff is fucked
Old Jun 7, 2010 | 07:45 AM
Butch.'s Avatar
Butch.
thats why he suggested welding it up! I thought sum1 on here wud have welded there diff up!
Old Jun 7, 2010 | 07:47 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Send a PM to JB Fletch. He knows exactly how to do it
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Get a decent Diff SIMPLE!!!!
Old Jun 7, 2010 | 08:06 AM
ram's Avatar
ram
Has a large member
Im rockin a welded diff in my saph at the mo
good fun but horrible when on full lock or cornering slowly at the petrol station while your car jerks around and tyres screech whilst everyone looks at you lol
Old Jun 7, 2010 | 08:30 AM
R4N SS's Avatar
R4N SS
its not that hard to do - do a google or youtube search
Old Jun 7, 2010 | 08:51 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Weld the plant & sun gears together & to the casing Easy.
But dont weld the entire hole up with the planets are as you still gotta be able to take the diff apart, you should be able to get to the circlips that hold the driveshaft bells in.
Only things that'll give up after that are the CWP & snappin drive shaft bells in half or where the pinion bolts onto the prop.
But it is a hell of alot stronger I went from breakin 28 diff's in a year to about 7 I think so you could say their 4 times as strong lol
You can see from this pic what I mean, ignor the failed CWP lol
jb
Old Jun 7, 2010 | 04:05 PM
Butch.'s Avatar
Butch.
cheers jb thats a great help! is it weldable just by taking the end casing off or do you have to take the internals out aswell? looks like this is my next job... weld all the gears together and what you mean by weld the casing aswell?
Old Jun 7, 2010 | 04:10 PM
cossiedrift's Avatar
cossiedrift
On both of mine i just dropped the back plate off sprayed brake cleaner to clean it out then i welded the sun and planet gears and the pin the whole jon lot together and they have both taken abuse especially the 3dr 1.
Old Jun 7, 2010 | 04:13 PM
Butch.'s Avatar
Butch.
right so basically weld everything together lol...
Old Jun 7, 2010 | 04:22 PM
Takeshi's Avatar
Takeshi
I thought one wheel wonders are the norm when it comes to open diff's?
Old Jun 7, 2010 | 08:02 PM
foreigneRS's Avatar
foreigneRS
Testing the future
they are, but the cossie doesn't have an open diff
Old Jun 7, 2010 | 08:09 PM
martysmartie's Avatar
martysmartie
If spinning one wheel and wanting to repair, it probably just needs a rerate or replace with a plated diff.
Martin
Old Jun 7, 2010 | 08:25 PM
Ben M's Avatar
Ben M
might aswell have they never work properly
Old Jun 7, 2010 | 08:51 PM
Butch.'s Avatar
Butch.
Old Jun 7, 2010 | 11:33 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Weld the plants & suns to the diff casing. Dont weld in the centre cos if you bust anything you wont be able to take the diff apart
You can weld it in situ if you want but be sure to give it a huge clean after cos splatter from the welder could get on the CWP & damage em the second the drive the car.
Last one I did was in situ & has lasted so far (bout 6 months now)
Will try find more piccy's
jb
Old Jun 7, 2010 | 11:42 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Pic's
Dead one lol
Thought I had more pic's than that !!
jb
Old Jun 8, 2010 | 06:56 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i put a plate in there as well on mine so that the only things that could possibly break could be the pinion or crownwheel. i removed mine, drained out all the old oil, cleaned it thoroughly with brake cleaner and stuffed it full of rag to catch any spatter.
Old Jun 8, 2010 | 01:08 PM
Butch.'s Avatar
Butch.
just found this on google
so literally just weld all the gears together and to the case looks nice and simple to do
Old Jun 8, 2010 | 01:45 PM
Ryan_3's Avatar
Ryan_3
just buy a quaife atb
Old Jun 8, 2010 | 01:53 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
There's a 'slight' price difference between a Quaife, and some welding though!
Old Jun 8, 2010 | 02:04 PM
Nash's Avatar
Nash
Cake lover!
Also whats the point if its just going to be used on the 1/4 and no road use. £1k for the ATB or £100 for a standard one welded up, no brainer for me if i was doing straight line stuff.
Old Jun 8, 2010 | 02:14 PM
XRT_si's Avatar
XRT_si
Agreed, a Quaife ATB is FAR from ideal for drag racing, a welded actually has quite a few benefits.
Old Jun 8, 2010 | 05:19 PM
Butch.'s Avatar
Butch.
the car has done 800 miles in just under 2 years and thats with me running the new engine in!!! he just literally takes it for m.o.t each year and drives it to santa pod for the ford shows.....
Old Jun 8, 2010 | 05:45 PM
Ryan_3's Avatar
Ryan_3
I see sorry
Old Jun 10, 2010 | 04:33 PM
Takeshi's Avatar
Takeshi
Sorry my mistake haha, I should pay more attention next time
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
