Help Help Help..
Old Jun 5, 2010 | 01:47 PM
Mark Hiller's Avatar
Mark Hiller
Default Help Help Help..
I have a 92 escort cos, overtaking in 2nd gear , reved to about 4000rpm then spluttered, now on idle when try to rev a little just wont , just pops and splutters, changed plugs and dizzy , no change, any ideas? Thanks
Old Jun 5, 2010 | 01:48 PM
northernmonkey's Avatar
northernmonkey
I didn't do it!
Boost hose?
Old Jun 5, 2010 | 01:52 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
As above, it's just popped a hose I'd say.
Old Jun 5, 2010 | 01:54 PM
Mark Hiller
Anything else?? Not a mechanic so dont no where boost hose is? would it leak?
Thanks
Old Jun 5, 2010 | 01:57 PM
northernmonkey
I didn't do it!
It'll be that BIG pipe coming off your turbo!
Old Jun 5, 2010 | 01:58 PM
Mark Hiller
lume plugs? that mean nething as its a big turbo model , 92 escos
Old Jun 5, 2010 | 01:59 PM
D.K.'s Avatar
D.K.
As above, sounds like the boost hose to me too
Old Jun 5, 2010 | 02:04 PM
Mark Hiller
ok kool, just spoke to mark shead n he sed lume plugs, I dont even no what thy are either , b ut thanks for all your help.
Old Jun 5, 2010 | 02:05 PM
Christian and Beccy
#1 in Spelling Club
Could be any of the hoses from the turbo>intercooler>throttle body, or indeed one of the smaller vacuum pipes.
If you don't know what you're looking for, then time to get someone to look at who does. I bet it is that and not worth looking at anything else.
Old Jun 5, 2010 | 02:06 PM
Mark Hiller
ok cheers, thanks.
Old Jun 5, 2010 | 02:08 PM
xr_craig's Avatar
xr_craig
Mine did that, it was the pipe on the map sensor
Old Jun 5, 2010 | 02:10 PM
Mark Hiller
can I connect the pipe back up? is that a jubealee clip?where is it? cheers.
Old Jun 5, 2010 | 02:11 PM
Christian and Beccy
#1 in Spelling Club
Likely that whatever hose has come off can be simply put back on and re-tightened. It is possible that its a split hose, but not as likely as it just coming off.
Old Jun 5, 2010 | 02:13 PM
xr_craig's Avatar
xr_craig
depends how it's failed mate, mine had cracked and needed a new sensor. My mate managed to glue his back together as a temp fix.
It's under a little bracket on the inlet side of the engine. Pipe goes from inlet to it.
Old Jun 5, 2010 | 02:14 PM
Mark Hiller
ok guys thanks very much for all your help. guna get the bonnet up thanks again
Old Jun 5, 2010 | 05:44 PM
billybigspuds's Avatar
billybigspuds
boost hose map sensor etc
R5FORD
Oct 22, 2010 07:54 PM
Jucks
May 4, 2008 03:52 PM
JanDK
15
Jun 8, 2007 10:48 AM
GuGu
Mar 20, 2007 08:43 AM
