st200 problem?
Old Jun 4, 2010 | 05:17 PM
cloakingzander's Avatar
cloakingzander
Default st200 problem?
folks, jst thought id pick ur brains im avin a few problems wiv my st200. i seem to be suffering from power loss,rough idleing and rising revs to about 3000 wen clutch is dipped. iv ad it serviced new plugs idle control valve cleaned and also checked the irmc this seems to be working fine. u guys av any ideas?
Old Jun 4, 2010 | 05:32 PM
RichieST's Avatar
RichieST
Is it idling high all the time? I'd be looking at an air leak after the air flow meter, maybe split pipework/inlet manifold gasket etc.
Old Jun 4, 2010 | 05:40 PM
cloakingzander
i can hear an hissing sound coming from the back of the engine but dnt know wots around that area for me to check. but its not doin it wen engine cold. so dnt know if it could be a split pipe etc effecting it.
Old Jun 4, 2010 | 05:51 PM
RichieST's Avatar
RichieST
Sounds like inlet manifold gasket or the manifold itself cracked, metal expanding when it gets hot so the hole appears. You can try some of that easy start stuff, spray it around where you can hear the hissing. If the revs fluctuate then bingo, you've found the leak.
Old Jun 4, 2010 | 05:57 PM
cloakingzander
il try that 2moz fella. thanx for the help.
Old Jun 4, 2010 | 06:05 PM
Fiddy's Avatar
Fiddy
check the air intake pipes, clean the maf, check the throttle position sensor.
Old Jun 4, 2010 | 06:14 PM
cloakingzander
where do i find the throttle position sensor?
Old Jun 4, 2010 | 07:12 PM
cosmo V6's Avatar
cosmo V6
What is it like when you drive it and pull up to a junction or dip the clutch.
Old Jun 4, 2010 | 07:17 PM
cosmo V6's Avatar
cosmo V6
http://z7.invisionfree.com/SouthWale...?showtopic=108
Old Jun 4, 2010 | 07:21 PM
cloakingzander
wen i first start it and drive it it pulls ok except it feels like its missing on idle. wen its warm it feels like its lost power. all symptoms point to irmc but checked that and its fine. wen i dip the clutch the rvs will either stick or raise to 3000 rpm
Old Jun 4, 2010 | 07:25 PM
cosmo V6's Avatar
cosmo V6
Arrow
click the link
Old Jun 4, 2010 | 07:50 PM
Fiddy's Avatar
Fiddy
a knackered IRMC wont cause any problems at all, bar over 3K revs the secondaires wont open, hence, you want get that big pick up in power. bar that, the car wont run any different
Old Jun 4, 2010 | 07:54 PM
Where is the throtttle position senor at then?
Old Jun 4, 2010 | 07:59 PM
Fiddy's Avatar
Fiddy
if you havnt already, relocate the IMRC to the battery tray as there prone to failing. its a a quick an easy job.
Mine
Old Jun 4, 2010 | 08:06 PM
Who did that for you fiddy.Nice shot of the throttle position sensor there in the first pic.
Old Jun 4, 2010 | 08:13 PM
Fiddy's Avatar
Fiddy
On the throttle body IIRC. its quite common for the V6 2.5 to get the symptoms the thread starter is having, and a lot of times its the TPS.
A bad TPS can have many effects:
Hesitation on acceleration
Rough idle
Jerkiness
Rough running
Might not be the TPS, may be the old throttle hang thing rearing its ugly head, but im not to clued up on the throttle hang fix, or wether it would cause the problems he is having, but throttle hang is also a common problem on 2.5 V6 Duratecs.
Old Jun 4, 2010 | 08:14 PM
Fiddy's Avatar
Fiddy
Some nice bloke from darlington with a white saff
Old Jun 4, 2010 | 08:23 PM
Well i would reckonmend to anyone who has a V6 mondy to move the IMRC to the battery try.I did fiddys and thought i wouldnt be able to tell the difference but i could tell that it was working right/better.
Old Jun 4, 2010 | 08:27 PM
Fiddy's Avatar
Fiddy
Thats because the old one was fooked mate, the new one actually works, the old one didnt lol.
Ive heard of him but ive never seen him around.Ive heard he is a right ugly looking coont.
Old Jun 4, 2010 | 08:30 PM
Fiddy's Avatar
Fiddy
Aye, he's a bit of an ugly cunt, but he's a nice bloke, got a nice car, and his wife's a tidy boiler, how he's pulled her, ive got ne idea
Old Jun 4, 2010 | 08:41 PM
Lol i wouldnt mind sorting his tart out she is fit.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
