last cry for help before it has to go
#43
engine servies in Dunston 0191 460 5256 ask for gordon rebuilt my s1 engine all new parts cost £1k but will no doubt have a look for you and tell you whats wrong.
#44
I know a lad who is excellant with engine work and does all mapping work but mainly for evo's and scoobs but he is from a cossie background but he is VERY well known on the MLR, here's his website
http://www.evotune.co.uk/
also has the STANDARD ECU power record in the UK for evo's with a 686 bhp all built and mapped by him so he knows what he is doing
#47
alreet m8 i work for a garage in houghton and we work all rs m8 my boss owns 2 rs we got gordon from his club to bulid his s2 engine so if u stuck give me a shout i have a word with my boss and see if we can help u out in any way m8 houghton in sunderland
#57
Mate just rebuild your engine top to bottom, you should be able to do it for £1500 easy including new pistons and new bearings, oil pump etc. Then you will effectively have a brand new engine, and peace of mnd.... Get a decent machine shop to match the rings and pistons to the bore, and rebuild the head etc, and just bolt it together.
#58
as said; rebuild it and you can do it for £1500 if doing it yourself or find someone who can give you a hand
depends on what needs doing to your engine to get it back to tip top, but rough prices
bottom end refresh
New pistons with rings & pins £440
re-bore £80
Bearings £100 ish
oil pump £160
head bolts £not quite sure
grp.a head gasket £150
gasket set £80
other cost to consider is if the crank needs a grind, costs will vary quite alot, just get a decent machine shop to do it
tope end will heavily depends on if you need guides, seals, skim, tappets etc
bottom end refresh
re-bore £80
Bearings £100 ish
oil pump £160
gasket set £80
#60
Dont worry it will get sorted.
#63
y dont you just pallet it up be about 50-100.00 i know a few people who will rebuild that for you 1 person is johnyjn on passion ford have a word with him
#66
he said full engine rebuild for £1300 including new pistons.
Thats £800 for shells, rebore, crank grind as it will prob need it at the least, Valve guides, lap the valves back in head skim and clean up/decoke thing, all the gaskets including head gasket, the guys time to put it back together.
and im probably missing loads. what about oil pump and water pump? Cam belt!
i would not trust youre engine mate sorry!
#67
best of luck with this mate
I was quite lucky with mine I didn't really have mine long enough for something major to go wrong with it
#68
The fuel pressure regulator is normally attached to the end of the fuel rail above the distributor, FSE ones do not seem to work well on a turbo engine and the original Weber Marrelli one is very reliable so go back to that for a start.
Have a look through Billy Yums thread where he asked about peoples Cossy engine bays, you should see what most people have and what your missing.
A proper overhaul can cost well over £1500 but for the basics that should about cover it if you do the work yourself. Expect upto another grand on top of that if you pay anyone to do it
