FAO Electricians???
Old 01-06-2010, 02:41 PM
mercury grey minter
mercury grey minter's Avatar
Default FAO Electricians???
I have a fuse box come meter cupboard under the stairs.I want to put a toilet there so need the fusebox/meter moving about a metre .How much should i pay roughly and is it easy/straight forward job.?
Old 01-06-2010, 03:01 PM
Gaz 88
Gaz 88's Avatar
you will have to move everything out of the toilet including the cut out fuse and meter so this could involve getting the feed to the house in a diffrent way off the electric board which would be costly!
Old 01-06-2010, 03:50 PM
danneth
TORQUE!
danneth's Avatar
hard to say without seeing it, but more then likely looking at the best part of Ł500
Old 01-06-2010, 07:11 PM
vernam616
vernam616's Avatar
Same again, its hard to say without looking, could you arrange a picture maybe?
a possibility is getting some boxing made which covers the full electricity boards supply/meter (with access if needed), then re-route the fuseboard to the other side of the wall, if you can get it done on a cheap/mate, it should cost no more than 150 quid
Old 01-06-2010, 07:20 PM
joe s
joe s's Avatar
Unless it will go to the otherside of the wall without disconnection, the supplier will need to do it, the meter is their property. Electricians can only touch from the fuseboard! ŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁ
Old 01-06-2010, 07:47 PM
Shings
Shings's Avatar
Oh and Part P everyone.... dont forget Part P.
Where about in Solihull are you??
Old 01-06-2010, 11:15 PM
mercury grey minter
Here,s some pics.I want to move the stud wall about 3 foot to the right so i can put the toilet & sink in.
Old 01-06-2010, 11:20 PM
mercury grey minter
I,m opposite SEARS RETAIL PARK.
Old 02-06-2010, 03:28 PM
mark r
mark r's Avatar
that job as you need to move the incoming supply can only be done by your ele supplier,if you do move it by not using them they could take you to court
Old 02-06-2010, 03:58 PM
vernam616
vernam616's Avatar
ahh that is a bit of a bastard, looks like its going to cost you big mate, + there is no DP isolator in place, so electricity board would have to disconnect your meter tails and reconnect if you moved the consumer unit
can you not go 3 foot the other way?
Old 02-06-2010, 07:22 PM
CHRISP
CHRISP's Avatar
as said mate you're going to need a double pole switch fitted by your supplier, your meter tails look a little under sized as well though it may just be the pic
Old 02-06-2010, 08:09 PM
mercury grey minter
If i get the electric supplier to move the meter,how much would a sparkie charge to move the fuse box.??
Old 02-06-2010, 08:17 PM
vernam616
vernam616's Avatar
will have to move the whole lot, would mean digging the mains incoming cable up, jointing it and re-routing, and we are talking big money here, never heard of someone doing it but expect at very least a grand just to move it
Old 02-06-2010, 08:19 PM
vernam616
vernam616's Avatar
Looks like the meter tails from boards fuse - meter are 16mm and the tails - D/B are 25mm
van_dogg_pavvy
03-03-2016 09:30 AM
Chris S
04-01-2007 07:11 PM
DaveEscos
11-02-2005 11:33 AM
Quick Reply: FAO Electricians???
