Focus St mk2 help!!
Old May 26, 2010 | 12:55 PM
alan12112's Avatar
alan12112
Focus St mk2 310 bhp :D
Default Focus St mk2 help!!
Right guys,
Bit of a problem here my car is tuned to 300bhp with a induction kit, downpipe, sports cat, remap and a intercooler.
It's been into ford twice for an oil leak in 2 weeks, 1st time it was a oil gasket housing diaphram that cost me near on £500 to get sorted (including and oil and filter change) - a week later it's was still dripping oil and when I checked it only had a smidge in the car, so I took it back and they said it was an o-ring seal on the return pipe of the turbo which they sorted, since then it has dropped boost pressure to half - so i've sent it back and they now say it's got nothing to do with them and they wont touch the car cos it's modified!! It really annoys me as it was fine with turbo pressure until they looked at this o-ring thing!! AAAARRGGHH!!
If you drive along with the window down you can hear air venting when the turbo kicks in - which it has never done before
So I need help please guys! i'm stuck now, does anybody know any good and reputible focus st tuners in the North west and what do we think it is?
I though it was just a boost pipe that had dropped off from when they fiddled with the turbo but not according to them!! Grrrrrr
Old May 26, 2010 | 01:03 PM
Paulo P's Avatar
Paulo P
The diaphram is known for splitting on these and it causes a high pitched whistle and a loss of boost.
Old May 26, 2010 | 02:02 PM
alan12112's Avatar
alan12112
That was the initial problem Paulo
Old May 26, 2010 | 02:27 PM
Paulo P's Avatar
Paulo P
I see that now I don't know what is causing it now.
Old May 26, 2010 | 02:32 PM
ECU Monitor Enthusiast
If the diaphram is fixed...
I reckon they have loaded the ecu with the original map as this is done by default on the Ford WDS system sometimes when doing diagnostic checks
Old May 26, 2010 | 02:56 PM
jonnyboy's Avatar
jonnyboy
reputable firm in the northwest would be profile auto evolution
http://www.profile-automotive.co.uk/
gary is the man to talk to but simon is probably correct.
my oil filter housing when and was changed under warranty but the part only cost £135 max and take an hour or so to fit
Old May 26, 2010 | 03:07 PM
alan12112's Avatar
alan12112
I though this so I reloaded the dremascience map myself yesterday and the problem stayed!!
Jonnyboy - is that Gary Lendon? if it is i've spoken to him at a few car shows and he seems like a decent fella!!
Old May 26, 2010 | 03:36 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Did you get the old diaphram back when it went in initially?? ...wouldn't surprise me if they sacked off changing it/wanged in a replacement quickly and just melted your car down some local roads instead. A 300bhp ST is going to be a good job to get instead of Granny Smiths 1998 Ford Ka coming in for its annual service.
Cheers,
Grant
Old May 26, 2010 | 04:49 PM
RichieST's Avatar
RichieST
When you have been giving mine a fucking hard spanking and its really nice and warm you can hear the turbo spooling up and a bit of chatter too. Noticing it more with the warmer weather lately. Did you try putting the standard map back on with the dreamscience before you reloaded your tune back onto it? Certainly sounds like you don't have the right map on it, if a boost pipe had split it probably wouldn't boost at all and it would chuck up a fault code.
Old May 26, 2010 | 09:42 PM
jonnyboy's Avatar
jonnyboy
thats the fella, based in stockport. top guy with normally excellent results
Old May 27, 2010 | 08:24 AM
alan12112's Avatar
alan12112
Cheers,
Grant
Never got it back mate no - I hope they haven't done what you've said or i'm gonna drive the thing through the front fucking window of the service department!!
I didn't put the std one back on mate no, I just loaded the race plus map back onto it
i'll try tonight to do what you've said and see what happens
Yeah I checked the link when I got in and read that it was Mr Lendon - if worse comes to worse i'll have to take it to him
Any way went to see big Geoff @ CSG last night and besides calling me an idiot for going to ford he said he'll have a look at it on Saturday So fingers crossed he can sort it out
Old May 27, 2010 | 02:40 PM
RichieST's Avatar
RichieST
Another way to check if its got ford's software or the dreamscience on it is to see if your shift light works?
When mine was all standard the shift light wasn't enabled, but with the dreamscience on there it enables it. Comes on at about 6000 rpm if I remember right?
Old May 27, 2010 | 03:00 PM
Paulo P's Avatar
Paulo P
5900 to be exact
Old May 28, 2010 | 09:03 AM
alan12112's Avatar
alan12112
yeah I tried the load the stock tune then reload the performance map last night and it made no difference - the stock tune still boosted at 0.5 bar!
So I though maybe the dump valve has broken or something? I blanked it off with the ghetto broom blanker I made and during a short ride out you can still hear air escaping from somewhere!!
Old May 28, 2010 | 09:04 AM
jonnyboy's Avatar
jonnyboy
which intercooler is fitted? forge ones were famous for splitting
Old May 28, 2010 | 09:11 AM
alan12112's Avatar
alan12112
Think it's a pro alloy one - i'll have to check when I get back home tonight
Old May 28, 2010 | 01:58 PM
jonnyboy's Avatar
jonnyboy
if its pro-alloy it wont be split,never heard of any issues with those but if its the code red copy you may well have an issue,has there been any esp system failure lights displayed?
Old May 28, 2010 | 06:27 PM
big mac's Avatar
big mac
it maybe the pipe from the intercooler to throttle body that they would have disturbed to get to the oil leak
Old May 28, 2010 | 06:51 PM
vaughant's Avatar
vaughant
Certainly sounds a boost hose issue to me,they're the same engine as a Volvo I believe and i've just removed a turbo on one this week.from the airbox into the turbo inlet pipe via a big connector where there's loads of little pipes which are boost related,anyone of them could be split with ease,especially as some of them are really awkward to get at and some heavy handed apprentice may have pulled rather than undone a pipe causing even a loose connection,try down there young man.
TPM961
Jan 15, 2018 10:50 AM
richierich1986
Sep 18, 2015 03:29 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
