Bouncy saph speedo needle,what causes it ?
Old 23-05-2010, 05:50 PM
KSA-Cossie
KSA-Cossie's Avatar
Default Bouncy saph speedo needle,what causes it ?
Only does it up to 50 mph ?
Old 23-05-2010, 06:12 PM
Karl 3dr
Karl 3dr's Avatar
Mine did this, came down to the inner part of the cable not being fully into the drive in the box, mine's 2wd though, dunno if yours is different.
I just refitted mine and it was ok.
Otherwise, worn speedo drive, kinked/damaged cable?
Karl
Old 23-05-2010, 06:17 PM
cossie daz
cossie daz's Avatar
mine also did this but was ok after a few times of driving
Old 23-05-2010, 06:22 PM
KSA-Cossie
KSA-Cossie's Avatar
Cheers guys.
Old 23-05-2010, 06:23 PM
Dicko&Vacant
Dicko&Vacant's Avatar
mine also does it lol upto about 30 then its fine
Old 23-05-2010, 06:28 PM
PAUL S
PAUL S's Avatar
dried out cable a lot of the time so it snatches as it goes around at low speed
Old 23-05-2010, 06:30 PM
KSA-Cossie
KSA-Cossie's Avatar
Can you still get new cables ?
Old 23-05-2010, 07:25 PM
Karl 3dr
Karl 3dr's Avatar
You cant get genuine ones but you can get non gen ones off ebay, they're not brilliant though
Old 23-05-2010, 07:29 PM
KSA-Cossie
KSA-Cossie's Avatar
Gotta be better than mine though eh karl
Old 23-05-2010, 07:37 PM
Received 1,044 Likes on 998 Posts
Does msd not sell them.
Old 23-05-2010, 07:39 PM
KSA-Cossie
KSA-Cossie's Avatar
Don't think so glen.
Old 23-05-2010, 07:41 PM
Frogford
Frogford's Avatar
Spasms in your right foot !
HTH
rostill2007
rostill2007's Avatar
not sure if you can on sierras but on some cars you can take the cable out of the liner and you could grease it up again if you can maybe ask someone who has one off there car while doing a resto or something if this is possible
Old 23-05-2010, 07:44 PM
t4 and greys
cosworth gimp
t4 and greys's Avatar
try taking your cable off and leaving it to soak in a bucket of oil overnight ..
let the excess drain off and clean the outer up then re-fit
also when refitting as stated make sure the box end is pushed in all the way
mine worked fine after this and prior was bouncing to 40 in reality was only probably doing 15mph lol
KSA-Cossie
KSA-Cossie's Avatar
HTH
Erm............................................... ...........................nope.
Old 23-05-2010, 09:08 PM
PAUL S
PAUL S's Avatar
you can slide the inner cable out easy enough and clean it up, then oil as described above
Old 23-05-2010, 09:14 PM
xr4x4rs
xr4x4rs's Avatar
possible cable but can also be the drive gear as its only made of plastic
Old 23-05-2010, 10:07 PM
Karl 3dr
Karl 3dr's Avatar
True kev!!
Old 24-05-2010, 04:40 AM
Smit
The 60ft Launch King
Smit's Avatar
How easy are these to change?
Old 24-05-2010, 07:23 AM
muffster
muffster's Avatar
I had the exact same problem on mine. I had heard it could be something to do with the spirngs inside so i took the clocks out and had a look at the plastic wormgear which drives the needle. Their was nothing obvious but i had a good look around and turned all the gears buy hand. After that and a good wd40 ing, put it back in the car and its been spot on ever since.
Hope this helps.
Muffster.
Old 24-05-2010, 07:52 AM
Mike Kerbey
Mike Kerbey's Avatar
I bought one from burton a few weeks back, but its abit short and the cable inside kept sliding up inside of the sleeving and falling out the drive on the gearbox!
Rsmat
89
12-10-2015 07:50 AM
07-10-2015 12:56 PM
gcfcos
59
06-10-2015 05:04 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: Bouncy saph speedo needle,what causes it ?
