Help please!!!! Wrong Fuel!!! Petrol in Diesel tank.
Could do with a little advise guys. To cut a long story short :-
Whats the best way to drain the tank?
I'm in the Edinburgh area if anyone is local and has recommendations of someone that can carry out the work at the house.
- I've a full tank of V Power in our Mk5 Golf TDi.
- The engine has not been started.
- The car has been recovered home.
as stated above ur lucky really as you wont have to contend with gettin it out of the injection pump and rebleeding the system wich can be a right pain in the arse
People are getting confused, petrol in a diesel car will not make it run better, diesel in petrol can potentially clean the system. Drain the tank completely if it hasn't been driven and you should be ok.
i once thought that the £20 worth of high octane my gaffer put in my moms trooper would run my car because his ran ok with it but no i had to leave it running for days with the key in the ignition and then the plug died before it ran out
right get a long flexi tube (water tight) insert one end in to the fule tank as far in as yoy can then suck on it untill you get a mouth full of petroll and point the end of the pipe in a basin ect below the lowest point in your fule tank, the end of the pipe MUST be lower than the bottem of your tank, yoy may allso have to suck o the pipe a few times to get it started, then simpally dillute with a full tank of deisil whats left in the fule tank and your ready to go
You could do that or remove a hose from the tank to drain it. Is there a hatch under the rear seats for the pump? Could do it that way aswell.
may be an anti syphon on it thouggh as it is a new car i wouldnt draw it up through the pump more ball ache imo has you looked to see if there is a drain plug in the tank itself
this should work but then it may cut out when it gets a bit of an airlock may well start straight back up afterwards mind but removing the pipe from the tank may well be the longest easiest option sound like th op has it sorted now anyway
we were in a petrol stationa dn needed soewhere to put all the diesel, so we bought loads of bottles of evian, emptied them and used them. he had all the diesel in his oot for about 4 months afterwards still
iv had to do this for a mate and all i did was undo the pipe going onto the filter and put a pump on it and let it pull all the petrol out then i put £5 of good fuel in the tank and turnd the pump on again so the last bit was all most %100 clean then put £10 in and sent him strate to fill it to the brim and it was spot on and it was all done in the time it tuck to make a cup of tea job done
As said you have done right in that you haven't started it, so the fuel lines etc won't be contaminated so simply drain the tank and refill with the correct fuel, I am surprised that the filler neck didn't prevent this from happening, certainly the new Fords make it impossible to fill with the wrong fuel. Removing the fuel line will not keep the pump going, it will just prime as usual, should think Diesels are the same, in any case I would not recommend this way.
Martin
Martin
Half a gallon of petrol to a full tank of diesel is a good one just as you are taking your car for an MOT.
