Mounting a TV onto a stud wall
Old 20-05-2010 | 08:06 PM
john's Avatar
john
Default Mounting a TV onto a stud wall
Can i do this ? If so what is needed and the best way to do it.
Complete novice so an idiot guide please.
TV is 42 inch and weighs 14 kg.
John
Old 20-05-2010 | 08:16 PM
baz walton's Avatar
baz walton
Rock Out!!
If it is indeed a stud wall, (pasterboard over a stud frame) then the only job you need to sort is exactly where the studs are. You could borrow a stud finder, which basicly finds the nails in the wall or look for clues in the wall, (plaster sometimes dips in slightly where boards meet). once you know where your vertical studs are, then screw your brackets to them. Stud is normally 3"x2" so you dont need monster screws, but they have to be in far enough to take the weight.
If the brackets for the tv have to be in a certain place on the tv, and that is a different width to the stud, then a simple bracket between them will have to go on.
hth
Baz
Old 20-05-2010 | 08:20 PM
john's Avatar
john
Cheers Baz.
On other thing, The stairs are on the other side, Me falling down drunk one night won't affect it with any vibrations will it ?
Old 20-05-2010 | 08:22 PM
oibren85's Avatar
oibren85
If in Doubt Flat Out...
I've got 4 coach bolts into stud walls and the expandable plasterboard anchors fixings. this is holding a 60 inch LG tv on the wall no worries.
http://www.thesitebox.com/Product/18...ll-anchor.aspx
Thats what you want, check the depth of the wall and order the correct anchor
Old 20-05-2010 | 08:41 PM
baz walton's Avatar
baz walton
Rock Out!!
Those expanding bolts will work, but not as much peace of mind as going into the stud, especially if you are going to be up and down stairs that are attached to the wall.
Old 20-05-2010 | 08:48 PM
RichieST's Avatar
RichieST
https://passionford.com/forum/genera...l-shes-up.html
Have a look here, should tell you everything you need to know. Put my 41kg plasma on a stud wall and its been fine!
Old 20-05-2010 | 08:49 PM
barnard's Avatar
barnard
plasterboard fixings
Old 20-05-2010 | 08:55 PM
RichieST's Avatar
RichieST
Maybe yes for a picture frame, probably not for a telly
Old 20-05-2010 | 08:57 PM
barnard's Avatar
barnard
Gripfill hammer nails
Old 20-05-2010 | 09:01 PM
danneth's Avatar
danneth
TORQUE!
mk3ste
17-10-2021 10:09 AM
Cosnada
07-01-2016 05:30 PM
gcfcos
59
06-10-2015 05:04 PM
martynhomer01
01-10-2015 12:05 AM
DavidK
27-09-2015 02:55 PM
Quick Reply: Mounting a TV onto a stud wall
